Question about Tascam Audio Players & Recorders
Need capstan belt for reel to reel -tascam-dx-44,pls help.
  • Tascam Master
  • 1,258 Answers
The model is not a DX44 as that is a dBx unit attached to either a Tascam 44 or 40-4. The tape deck model would need to be determined and when that is done go to Marrs Communications and order the belt kit for that machine and you will get the capstan and counter belt.
http://marrscommunications.com/tascam-cassette-kits
Posted on Apr 04, 2013
SOURCE: i need a service/owners manual fora tascam 38 reel
they are available on ebay, but not free.
Posted on Mar 07, 2009
Grubhead
  • 5158 Answers
SOURCE: belt change for Teac a4010sl reel to reel
You can but try! However either make a drawing of how the thing fits together or better still take pictures if you have a digital camera. Then you will know how it fitted together.
Posted on Mar 23, 2009
SOURCE: replace capstan belts
(Unplug the unit before doing the following!)
Pull the top off (8 screws). On the back of each deck you will see a motor (silver cylinder 1.5"Diam x 1.25"Long) mounted to a removeable plate. It's kind of tricky, but... Loosen the bottom two screws securing the motor mounting plate (not the motor itself) to the rest of the deck. Then completely remove the top two screws, so the moter and plate fold away from the rest of the deck. With some care, you should be able to remove the old belt and slide the new belt over the capstan flywheel and motor pulley. Fold the motor assembly back into place and secure the screws. That should do it!
Note: I used a jeweler's screwdriver and needle-nose pliers to turn the screws on the motor mount. This is real fun with all the wires in the way, but it is possible. I Also pulled the screws on the power transformer, to move it, so I could get at one screw for deck #1.
BY THE WAY: I'm ready for new belts myself, and haven't been able to find a source, except in germany. Any ideas??????
Posted on Jul 31, 2009
  • 141 Answers
SOURCE: I have a TEAC reel to reel stereo tape deck, Model
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
Grubhead
  • 5158 Answers
SOURCE: I need a capstan drive
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Posted on Nov 06, 2010
How to replace capstan belt on Tascam 122?
Rob is essentially correct and I have gotten belts from Consolidated.
If you do not know the size of belts, you can simply order a kit from Marrs Communications and get premium grade Japanese belts. There is more to repairing these than just replacing the belts, there are new idler tires that should be installed and oiling of the bearings and even the reel table rebuild as these get dried out felt in them that develop too much take-up torque. Of course you would need a MTT160 test tape to find this and many local shops do not have them. I do because I worked for Teac before they closed down in Chicago. I was a Lead Technician there in the 80's. I am still working on these even today and have some 122 units in shop now. You are better served to have a Technician do the belts and oiling and all the other stuff that needs to be done such as setting speed and evaluation of the motor by wow and flutter measurement.
May 11, 2014 | Tascam Audio Players & Recorders
Reel to reel will not play
You do not mention the brand or model number which to answer the question effectively is needed- different machines are designed in different ways. The function of the fast wind and the play mode only differs in that in play a capstan is involved that regulates the speed and the reel motors just do the take-up of taper and a little back tension for the supply reel. You may have either a sticky Pinch Roller linkage or a non- rotating capstan shaft that might point to a loose or broken capstan drive belt. There are also the condition of the Pinch Roller surface and the surface of the Capstan shaft that can be glazed or rubber hard and non-compliant. The rubber Pinch Roller can be re-rubbered, the capstan shaft can be reconditioned and the Capstan Belt can be replaced. Capstan bearings and motor bearings need oil once a year as well. I hope this helped to some extent- I have been working on decks now for better than 40 years.
Dec 12, 2012 | Audio Players & Recorders
Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
skywavebe@sbcglobal.net
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Oct 31, 2012 | Audio Players & Recorders
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: pjheiland@hughes.net He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Oct 24, 2010 | Teac Audio Players & Recorders
Belt change for Teac a4010sl reel to reel
Mar 10, 2009 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
138 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
