HOW WE CAN PRINT FRONT SIDE & BACK SIDE ON ONE PAGE FRONT SIDE
    Genius:
  • 1,218 Answers
You make no mention of make or model so.....it is hard to help.
If your machine is not capable of duplex printing then the only way to get print on both sides is to put the paper back in the cassette a second time to print onto the second side.
Posted on Oct 10, 2010
PrintShop Mail, 7.2, print page front to back
Have you ever used: http://www.objectiflune.com/newsgroup/? It's a quick way to get a respond.
Nancy
Twitter @objlune
Oct 30, 2012 | Encore Computers & Internet
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Hi there! Printer: HP Laserjet 4100 Problem: does not want to make both side printing. Used settings: Printer Properties->Finishing->Print on Both Sides (click) Thanks for your...
To automatically duplex, you need the optional duplexing mechanism.
If you don't have this, your only option is to print the odd pages first, put the papers back in the tray, then print the even pages.
When you put the pages back into the paper tray, make sure they are print side up.
Try with a 5 or 6 page document first to be sure you get the orientation right.
If you HAVE the optional duplexing unit (which sticks out the front just above the main paper tray) then post a reply here and I'll try to help you further.
99% of the people that own this unit do NOT have the optional duplexer!
Mar 12, 2011 | HP LaserJet 4100 Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
How do I print double side
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print pages 3 & 4 on both sides and repeat for the rest of the document.
I suggest you try a test page first to get the printing right way up so the page reads correctly.
Dec 06, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
How do you print on both sides of a page??
If your printer does not have a duplex unit that allow you to print on both sides, then it is possible but a bit teadious because you have to print one page at a time.
Print page 1 and then place page 1 back into the paper tray but place the page so it can print on the other side of the page then print page 2.
Repeat for page 3 & 4 and so on.
Sep 20, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
How can i print the front and the back of my paper at once for lexmark x5470
When you want to print both sides of a page, when you go into the 'Print' command click on 'Properties' and another windows opens. Select 'Print Layou' and you will see a box marked 'Two-Sided' - click this box. The other option is if you want to flip from the top or turn from the side, like a book. Select which way (I use side flip) and click OK, which brings back to the start and click OK to print. Once the pages have printed you will still need to rotate the pages and place them back in the printer; there will be an instruction page printed halfway thru to show you which way to place the balance of the pages in the printer.
Might sound tuff, but once you've done it a coupla times, you won't even need to print the halfway intrsuction sheet. Good luck. Cheers.
Aug 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
59 people viewed this question
jasbo
jasbo
