Question about Acer Aspire™ T180 PC Desktop
My computer does not show any display, It has power but there is no display showing. I have checked all the cables, I have reset the memory, I have removed the battery and return it. Still not working.
  • joecoolvette
    joecoolvette Oct 10, 2010
    Sounds like a bad Power Supply. Weak voltage power rail. 1) ALL of the LED lights combined use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts. 3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is. Acer Aspire T180? Can come with an AMD Athlon 64 X2, or Athlon 64, or Sempron. Enough power to light LED lights, and maybe spin fans, but Not enough power to turn the Processor on. No Processor operating, No computer. No computer operating, No video signal to the monitor.
    Scholar:
  • 70 Answers
Try to connect the monitor to another computer and confirm the monitor is working fine. It might be an issue with the monitor
Posted on Oct 09, 2010
Sony Vaio EA series No display after LCD replacement (Sorry for my poor English, it's not my native lang) Booting and running computer on external display is ok. I suspect LCD cable is culprit, even...
check your memory card if its properly insert to the memory bank (note be carefull in touching memory card make sure that your is not wet & pls dont touch to the bronze in so forth, if not function change your memory card. if not try same in video card, you may also check keyboard power to press.
May 26, 2011 | Computers & Internet
My motherboard have power but no display on display on monitor
Hi roystonfer33 ,
make sure the cable connected to your Monitor is securely connected and firmly in place. make sure the monitor is plugged into the power socket properly. if there is still no display, then maybe trying another cable for the display.
Mar 17, 2011 | Intel Motherboard
I have compaq tft8020, from last 2 days i m facing problem. lcd is showing automatic"adjustment" between cable 1 or cable 2 with in 1 second.pc display is showing, but adjustment is continusely showing and...
mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
Aug 07, 2010 | Compaq TFT8020 18.1" LCD Monitor
DISPLAY NOT SHOW
Is the monitor light indicator flashing? if it so then kindly check the video cable connector and make sure it is firmly plug into the video port of the computer.
Did you hear some series of beeps coming from your computer?If it so then this indicates a hardware failure. Kindly reset the main memory card on the motherboard and also the dedicated video card if there is any.
Good Luck.
Thanks for reaching FIXYA.
Jun 29, 2010 | Intel Motherboard
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
Computer is not working
yes it is ur video card i suggest taking it to computer store
Nov 26, 2008 | E-Machines eMachines Desktop PC
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Hp photosmart C5250 all in one
Thank you for the information
Please check if you have inserted any Memory Card into the All-in-One.
Please perform the following steps:
1) Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please perform the following steps to reset the printer to factory settings.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord
Regards,
Sagarjd
Jul 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Acer Aspire™ T180 PC Desktop Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
