1994 Honda Accord Logo
Posted on Oct 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key is stuck in broken ignition of 1994 Honda accord EX .How do i remove broken ignition and replace a new one .Thanks
Duane Wong
Level 3:
  • Honda Master 6,826 Answers
  • Posted on Oct 09, 2010
Duane Wong
Honda Master
Level 3:
Answers
6826
Questions
6
Helped
2861952
Points
20234
REMOVAL & INSTALLATION 1994-95 Accord NOTE: Do not attempt to remove the ignition switch assembly if you do not have replacement bolts available. These special bolts have break-away heads which shear off when tightened. This is an "anti-theft'' measure used to prevent easy removal of the bolts. Fig. 2: Shear bolts must be used for reinstallation key is stuck in broken - 86806113.gif
  1. Disconnect the negative battery cable and disable the SRS system.
  2. Remove the dashboard lower cover/knee bolster.
  3. Remove the steering column covers.
  4. Unplug the ignition switch connector.
  5. Remove the two nuts and two bolts securing the steering column, carefully lower the column assembly.
  6. Use a center punch to mark each of the two shear bolt heads securing the ignition switch assembly to the steering column. Use a 3?16 in. (5mm) drill bit to drill off the heads. Take care not to damage the switch when drilling.
  7. Remove the bolts. Remove the clamp and remove the ignition switch assembly.
  8. Remove the three screws securing the switch and remove the switch. To install:
  9. Make certain the recess of the switch aligns with the tab of the lock housing. Insert the switch and install the retaining screws.
  10. Position the switch assembly on the steering column. Install the new shear bolts; tighten them finger-tight.
  11. Use a wrench or socket of the correct size. Tighten the shear bolts until the heads break off.
  12. Raise the column and install the nuts/bolts. Tighten the nuts to 10 ft. lbs. (13 Nm) and the bolts to 16 ft. lbs. 22 Nm).
  13. Connect the ignition switch wiring harness.
  14. Install the column covers.
  15. Install the dashboard lower cover/knee bolster.
  16. Connect the negative battery cable. Fig. 3: Be careful not to damage surrounding components when drilling 86806114.gif
    Fig. 4: The switch is secured by three screws
Key is stuck in the ignition
Make sure that the car is fully engaged in park, try rocking the car around just to be sure. Depress the brake pedal and try removing the key again if that doesn't work then there's a chance the key is bent somehow, and is not stuck in there the only way to fix that is to replace ignition or try prying it out but prying it out May result is broken ignition and not being able to use vehicle
Replace ignition key cylinder from 91 Honda accord
the ignition key cylinder comes as a single unit with the ignition lock assembly. if you want to use the same key as before take the entire lock assembly to a lock smith and they would be able to rekey the tumblers to match your old key.
3answers
1994 Honda Accord EX - will not start.
Possible timing belt, remove distributor cap and crank engine, if distributor rotor don't turn bad timing belt.
1994 honda accord ex pulling to passenger side at acceleration
Assuming your wheel alignment is perfect...........next thing to check is all the engine and transmission rubber mounting. Any worn or broken mounting should be replaced..........then the problem will be gone. Good Luck.
1helpful
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
2helpful
2answers
Key is stuck in ignition and wont release. 1999 Honda Accord. Key stuck in accessory mode.
If your car is auto, there should be a cable going from the shifter to the ignition to stop you being able to remove the key unless the car is in park. If the cable has become dislodged or broken your key won't come out. I would remove the shrouds around the column and have a look at the back of the ignition while moving the ahifter in and out of park. If your car is manual , I would suspect a bent key or a contaminated lock ( not common in a car this age ) Try Graphite powder, ( messy but effective ) it should be avaliable from your hardware store. Good Luck!
Can't remove key from ignition for '00 honda accord @ park positi
push key in turn on and off push key in work switch off and on .if dont release you probably going to have to take out the ignition switch. make sure your car is all the way in park.
HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
