Question about Everex StepNote SA2052T Notebook
My LAPTOP EVEREX SA 2052T batery does not charge. The power went off as soon as I take the Power cable. Please advice
  • Everex Master
  • 32,281 Answers
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Posted on Oct 09, 2010
  • 1 more comment
  • nenneregi Nov 22, 2010
    I have two batteries and neither will charge, and they didn't after the first two times. Mine also only works plugged in. What other problem could this be?
  • Chris Hingee
    Chris Hingee Nov 23, 2010
    It is possible that the power adapter is faulty or the laptop's power socket is faulty or the charging electronics in the laptp is faulty.
    To check the power adapter and the power socket in the laptop, please type in this link in your browser and follow my instructions :- http://www.fixya.com/support/r4799950-la...
  • lmproc
    lmproc Mar 06, 2014
    Can you still buy a battery for the Everex StepNote SA Series Notebook anywhere? If so, where?
I have an everex nc1500. it was on working fine, then it suddenly went dead like it was on battery,(but was on charger). now no lights come on ,it doesnt charge, doesnt try to turn on in any way. it acts...
This seems like a poor soldering job at the factory which has become loose/disconnected over time, affecting the power port the ac adapter plugs into. Take the laptop to the shop and have your power jack inspected.
Mar 10, 2011 | Everex StepNote NC1500 Notebook
No sound in xp when xp is installed.My system is Everex Step Note SA series 2052T.In vista no problem
Sounds like a driver problem. Vista has more built in drivers than XP. This link should start the download of the driver for you.
http://www.fic.com.tw/everex//us/support/sa2053t/xp/audio.exe
It says the model is SA2053t, but the same drivers are used for the SA2052t
Aug 19, 2010 | Computers & Internet
My hp pavillion dv7 1130us laptop will not turn on at all was working fine then stopes charging and then when batery went dead that was it I have no power at all now with or without the batery in
press and hold the Power button for 60 secs without the battery and power cable and then reconnect to it back and try to restart and if nb turns on then log on to www.hp.com and download the latest bios and install it as Administrator.
Aug 06, 2010 | HP Pavilion dv7-1130us laptop
Accidently hit my laptop with my hand, now the screen will not come on, when I plug the power cord in it only shows the charging light. When I try to turn the laptop on while it is charging it will not...
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 21, 2010 | Intel Everex LM7WE Notebook
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Fujisu laptop batery not chargin
try to check if other battery is working when being charge,if the problem is in ur battery u have to return and ask for replacement fron the store where you purchased it.nobody can repair battery pack.tnx
Jan 10, 2009 | Toshiba Satellite A105-S4004 Notebook
Everex Stepnote NC1500 wont boot
Are there any other lights on or any other activity, or does it just die? If it only pops up with the hard drive light briefly then dies, your laptop might just be dying because the battery isn't holding a charge.
Jan 08, 2009 | Everex StepNote NC1500 Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
New battery needed!
The Everex SA2052T uses the same battery as a Averatec 2260 (2200 series) laptop. I purchase one from provantage.com this week. The battery is made by BTI and the model number is AV2200. It works perfectly.
Nov 17, 2008 | Everex StepNote SA2050T Notebook
Help me
Witch password???
Bios password???
Everex has a known problem with this model of laptop. It has been known to set its bios password by itself. It is a simple fix, but should be done by a proffesional. There is no charge for this repair at a Everex repair center.
If you want, this is what needs to be done. Remove the piece of plastic above the keyboard. Unscrew the 2 screws in the keyboard and lift the keyboard up( No reason to disconnect it ) Unscrew and remove the modem card in the center. There is 2 solder points c88 on the system board. You need to short those 2 points out while you press the power button on. This will reset the bios password. This should take someone about 5 minutes to do.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause
Oct 25, 2007 | Everex StepNote NC1500 Notebook
Everex StepNote SA2052T Notebook Logo
354 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
