Question about Sony DVP-CX875P DVD Player
I have a sony dvp cx-875p dvd player. When the disk loads the unit works fine. The problem is loading the disk. Some disks attempt to load but do not pull back into the machine. The machine just makes a spinning sound, rests and then makes the sound again. Sometimes the disk loads on the first attemp, sometimes second or third. About 1 in 4 disks will not load at all. I have taken off the top, and observed, but see nothing wrong. The slot aligns with the rod that the disk rides into the machine on. I can't see what is pulling the disk. Does the pulling portion wear out? What are your thoughts.
  • rhgubrud Oct 09, 2010
    Is the part available? What is the part number? Is there an assembly parts explosion diagram? Do you know the approximate cost of the part?
    Is there a site that I can look at a diagram explosion of the parts in question. I am concerned with taking apart something that does not need to come apart, or putting it out of adjustment with no tools to get it back into adjustment.
    Would you have any idea of the part number?
  • Sony Master
  • 11,800 Answers
The disks are pulled in by a worm screw on which a plastic tab rests - if for some reason that tab jumps out of the groove of the worm . The screw motor will turn around for the time it normally needs to pull the disk in (the spinning sound you hear), detect that nothing happens, wait for a moment to allow the tab to fall back in the groove then try again.
This is caused by the normal wear of the mechanism and it can't be fixed. The only thing you can do is to grease the tracks very slightly to allow a smaller effort on the tab. The mechanism must be replaced - your big problem will be in finding a new one, since it's been out of production for a long time.
Posted on Oct 09, 2010
  • Azrael SRL Oct 09, 2010
    No, neither of them are available to the general public - this is Sony's repair policy. You can either attempt to fix it yourself or sent it to a dealer.
    BTW if you take it to an freelance repairman it will also open and try to fix it by trial and error so save the money and do it yourself - you have nothing to lose, the unit will stop working completely in the near future anyway.
    President:
  • 2,777 Answers
Yes it is an internal - hidden device that pulls it back in. The problem with this type of unit is it can only be replaced with the exact same mechanism. Some simpler - cheaper units can be replaced with a universal one. You are going to want to check with a local electronics repair shop, or with Sony directly to get this fixed up.
Thanks
Tim
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
All of the sudden our Sony DVP-sr200p dvd player is not loading our dvd's, it is stating "cannot read disk". Any solutions?
use soft cloth to clean the disc.
Examine the disc for any cracks or scratches that might be interfering with playback
Attempt to play another disc.
If another disc plays in the DVD player, then the previous disc is faulty.
If still the same. try to unplug for 3 hours. if the same. check sony.com/repair for service option
Oct 17, 2010 | Sony DVP-SR200P DVD Player
The dvd player does not load, but if we use it as
try using other new disk's and re check
see to it whether the lance is on a default position
if not lightly move it may be the gear is stuck.
regards
Apr 30, 2010 | Sony DVP-FX810 Portable DVD Player
Sony dvd player dvp-fx810 stuck on "disk loading"
Make sure the switch on the side is set to video out not video in hopefully this helps out
May 16, 2009 | Sony DVP-FX810 Portable DVD Player
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Won't read dvd
Try switching the LINE SELECT button from OUT to IN, then back to OUT. This solved the problem in which our Sony DVP-FX810 player showed LOADING for around 30-45 seconds and then CHECK DISC.
May 09, 2008 | Sony DVP-FX810 Portable DVD Player
DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
May 04, 2008 | Sony DVP-NS50P DVD Player
Player won't play any disks only says CANNOT LOAD DISK
you can try this
http://www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm
its for xbox but all cdrom drives are simulate
Dec 05, 2007 | Sony DVP-NS575P DVD Player
change the way you connect the dvd player to your tv
Jun 22, 2007 | Sony DVP-NS305 DVD Player
Sony DVP-CX875P  DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
