Question about Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Blinking power light. same even after unplugging and plugging ac power. relays click as if unit trying to come on, but at 2nd relay click, power light flashes.
  • 12 more comments
  • jesunkel Oct 09, 2010
    please send the link to service manual.
    Also, BTW, this model does not support HDMI connex.
    Thanx...
    The light blinks 11 times, then is on for about 2 seconds, then blinks 11 times again.
    No fan in this unit. P10 has no cable connected. FAN SOS appears to be a pass-thru to D PCB and into IC 9709.
    Also surprisingly little dust inside unit; vent ports not congested.
    Additionally, the manual I downloaded states that a fan problem would be 6 flashes and only gives data for up to 9 flashes. It does not have an entry in the "flash" table for 11 flashes.
  • jesunkel Oct 10, 2010
    No visible defects on the caps.
    Measured P2 and Vsus = 5.4v
    Measured P7 and 12v = 0
    measured P23 and DR15V = 0
  • jesunkel Oct 14, 2010
    Sent readings, what next?
  • jesunkel Oct 16, 2010
    They guy I was working with no longer replies, I have been charged, and problem did not get fixed.
    What gives?
    Hmmmmm, as I explained to the previous chap, there is no fan in this unit. The connector on the P board (P10) has nothing connected to it.
    I downloaded a Panasonic manual from a site recommended previously and in its error blink table, it indicates that 6 blinks would be the fan, and it does not have any entries in the error table greater than 9 blinks.
    Upon measuring some of the voltages at the output connectors for the P board there is for instance no 5v or 12v or 15v out.
  • jesunkel Oct 20, 2010
    Number of blinks depends on whether you are count the "off" period or the "on" period. If you count the off period, 11 blinks. If you count the "on" period, 12 blinks.
    There is, btw no fan in this unit.
  • jesunkel Oct 21, 2010
    Looks like 12.
    No physical defects to any caps that I can see.
  • jesunkel Oct 22, 2010
    Sorry, no capacitance measurement capabilities on DMM.
  • jesunkel Nov 17, 2010
    Replaced PS board, still same symptom. What now?
  • jesunkel Nov 19, 2010
    Yes, that's what prompted the PS replacement.
  • 4,889 Answers
Looks like some kind of protection fault, the source of which can be determined if you can tell me how many times the power light blinks in between each pause.
Posted on Oct 16, 2010
  • 3 more comments
  • eagle338
    eagle338 Oct 20, 2010
    No I am not talking about the period here. The power light is flashing right? It flashes a certain non of times followed by a pause then flashes again and so on.. I want to know how many times does the it flash between each pause. I can pin-point you to the location of the problem if you can tell me this.
    Sai.
  • eagle338
    eagle338 Oct 21, 2010
    12 blinks is a very familiar issue. It is related to the power supply board. The usual cause of this problem are faulty caps of high capacitance rating(>1000uF) . Look to see if you can find any of them bulging or cracked at the top or have tiny holes. If you find any replace them and that will most likely resolve your issue.
  • eagle338
    Does your multimeter have capacitance measurement capability? If yes then please set it to capacitance mode and range 10mF. See if it reads an over load. Sometimes the defects are too minute to be identified by visual observation. So multimeter would be the way to go. I am confident coz I have seen this before.
  • eagle338
    eagle338 Oct 22, 2010
    If so then please get me high res image of the board so that I can have a look.
  • eagle338
    eagle338 Nov 17, 2010
    Did you see page 42 of the Service manual given to you by Ginko before replacing? It has a flowchart that summarizes your problem
  • Panasonic Master
  • 19,396 Answers
Hi.
This TV (TH-42PA20U) has internal fan, that is reported in service manual. The 11 blinks is indeed P or PA board fan.
As probably explained the TV is in protect mode. Protect mode starts when a fault is detected. The second click that you hear is the protection switch turning off the PSU higher voltages to prevent further damage. Only the low standby +5v or +3.3V is allowed. As a result the TV will be forced to stand by.
As probably already mentioned, the 11 blinks means a problem with fan or fan control. Fan is tested energizing it and reading volts at connector.Fan control is located on PA board (DC/DC secondary PSU). This is a DC 15V circuit. A diode (D574) and the +15V transformer must be tested, along with the fan. +15 V coming from power board must be OK and steady.
The fan itself is rarely the problem, most of the time you have to test at component level to find the fault.
Here layout:
Here a suppletive service manual including circuit diagrams.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
  • Ginko
    Ginko Oct 27, 2010
    Hi.
    The service manuals clearly say that there are 4 fans in this model! Fans are +5 and +15V.
    From
    TITLE:
    Panasonic Services Company
    National Training for
    TH-42PX20U/TH-50PX20U
    TH-42PA20U/TH-37PA20U
    Plasma Display Panel
    I quote from manual:
    1) this must be tested, there are 4 fans (pg38):
    "Under normal conditions, the voltage drop derived from the voltage divider
    circuits at the base of Q9714 or Q9716 is enough to turn the transistor on.
    However should the voltage drop decrease, Q9716 or Q9714 respectively, turn
    off, allowing the 5 volts at their collectors to forward bias transistor Q9715. This
    effectively grounds pin 3 of the CPU triggering the shutdown condition.
    The four ventilation fans are monitored to be sure they are operating properly. If
    one of the fans opens or increases resistance, the resulting current change is
    applied to pin 37 of the main CPU.
    The Scan and Sustain voltages on the SC and SS boards are monitored in a
    similar manner. The +15V Line on the SS board is fed to a voltage divider and
    the result is compared to a reference voltage."
    2) this must be tested (pg36):
    "The DR15V source
    The diode D574 converts the AC output of the secondary windings of the
    transformer T502 to DR15V. This voltage source is applied to the SC and SS
    boards for Scan and Sustain operations. The PA board and fan control circuit
    also uses the DR15 voltage source. "
  • 10,515 Answers
As you have tried unplugging the TV for few minutes without any success, this would confirm that this is an internal fault and repair is needed for the same. If the set is under warranty, get it replaced or repaired at no cost. However, if it is out of warranty, either you could call a tech on site to get it repaired or you could go for DIY ( do it yourself ).You need to open the TV, might need to use multimeter or soldering iron. I would also send you the link where you could purchase the service manual as you need schematics to know the exact value of each and every component.If you want to fix it yourself, kindly provide few more details :-
1. When you press power button, do you get 2 blink pause 2 blink error?
2. Do you have anything hooked with TV with HDMI cables?
If you have HDMI cables attached, you need to remove and then unplug the TV for few minutes, say 15 minutes and then turn it on. If the problem persists, we need to move further and try to fix this problem.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Oct 09, 2010
    Thanks for your response!!
    You could buy the service manual from :-
    http://www.tradebit.com/filedetail.php/4...
    Kindly revert with more details :-
    Kindly revert, so that we could proceed and fix this problem.
    Hope i helped you.
  • taran_2005
    11 blinks indicate a problem with Fan SOS PB Board.
    Closer to a $150 repair if just the fan, you may even be able to change yourself for less.
    I
    would advice ringing around your local repair places and detail the
    fault light indicator and your interpretation and get them to price a
    fan replacement.There are thermal sensors throughout the TV, when a section starts to
    overheat it indicates a thermal problem in that section (in your case
    the PB board). It could be due to a failed fan, but it also can be due
    to a build up of dust in the vents and through the TV. You would have
    nothing to loose by unplugging from the wall and vacuuming the vents and
    ideally taking the back off and vacuuming in there as well.
    Let me know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    taran_2005 Oct 10, 2010
    I have a generic guide for all Panasonic EDTV plasma's. So, as you hear a relay click sound, i would like you to check the power supply board. Visually check for any bad / leaked / swelled caps. They might have ammonia kind of odor. Check the voltage across different points and let me know the result so that we may proceed.
    Hope i helped you.
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
TV stopped working
Since no brand etc listed here
Google the model number with 2 blinks and look at the results, you may find on another forum the answer to what it means and even a answer--error codes tend to be general in nature so do not expect it to point to a specific part.
Dec 19, 2012 | Televison & Video
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
Tv will not turn on and green light blinks 3 times constantly
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Jul 14, 2011 | Toshiba Regza 52XV645U LCD TV
My sharp XLMP 130 all of a sudden started blinking red four times and then one long one - nothing works??
The problem is with the "power on" relay (RL841) located on the power supply board. Unplug the unit and take off the side panel and top cover. Remove the screws to remove the CD changer. There is a small black rectangular relay just below where the AC cord is soldered onto the PC board. Carefully remove (actually break it off carefully and gently & throw away) the plastic top housing of the relay. Plug in the unit and with a pencil or stick, manually actuate the coil armature while pressing the power on button on the front of the unit. I can almost assure you your unit will return to normal operation. Put it all back together and you're done. The blinking red 4 times followed by a long pulse indicates a power failure. The start up capacitor had drained and couldn't provide enough voltage to pull the relay coil in all the way.
JP
Aug 04, 2010 | Sharp XL-MP130 CD Shelf System
Blinking Timer Light
Relay or capacitor on or by the power supply
Jul 08, 2009 | Pioneer DV-285-S DVD Player
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
TP55Hwon't turn on, after unplugging, click and red light flashes
I HAVE THE SAME PROBLEM ,I FOUND OUT AFTER OBSERVING FOR QUITE SOMETIME THAT THE CLICKING NOISE I HERE AFTER PLUGGING IT TO THE OUTLET CAME FROM A RELAY SWITCH LOCATED ON THE POWER BOARD AFTER TAPPING ON IT THE SET WOULD POWER AND THE BLINKING RED LIGHT GOES TO NORMAL..I BELIEVE THIS RELAY IS CAUSING THIS PROBLEM FOR ALL THE FELLOWS OUT THERE WITH THIS TV SET AND THE BLINKING RED LIGHT..IN MY CASE THE RELAY WENT SO BAD NOW THAT THE COIL THAT MAGNETIZES TO CLOSE THE CIRCUIT GAVE UP ,SO I PULLED THE COVER OF THE RELAY TO UNVEIL THE TWO METAL STRPS THAT COME IN CONTACT AND HAVE BENT ONE SLITELY TO REMANE CLOSE THIS POWERS THE TV UP NORMAL BUT IN ORDER TO SHUT IT DOWN I HAVE TO PULL THE OUTLET. THIS IS TEMPORARY UNTIL I CAN FIND WHERE TO GET RELAY SWITCH. PLEASE DONT TAKE MY RESEARCH AS A SOLUTION BUT FOR WHAT EVER ITS WORTH. I WILL GET THIS UP AND RUNNING AGAIN ITS ALL WORTH EVERY DOLLAR TO FIX.
Nov 18, 2008 | Toshiba TP55H60 55" Rear Projection...
Panasonic TH-42PA20U/P 42 in. Plasma EDTV Logo
221 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
