Question about Dell Latitude D600 Notebook
DELL INSPIRON 600M , WHEN TURNED ON ALL THREE LEDS LIGHT UP THEN THE CAPS ON BLINKS FOR 9 TIMES THEM THE COMPUTER TURNS OFF...PLEEEEASE HELP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
When the LED blink for couple of times and goes off its hardware problem with the computer... It might be a motherboard or the RAM that is causing this problem... Please take the computer to a local tech or call dell at 18006249896 to get the issue fixed
Posted on Oct 09, 2010
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Inspiron 600m laptop flashes the red light at the bottom of screen as if it needs charged, but it is 100% charged and is not hot or anything. It flashed red three times then green. I powed down unplugged...
when you use battery power, does the laptop work or does the battery die right away try letting the battery die itself, like use the laptop till it dies then charge it up again
Apr 05, 2010 | Dell Inspiron 600M Notebook
Affter i boot the system the green leds comes on and affter 10sec gos off everything
Maybe the processor of your computer have a problem maybe its over heated.
Oct 21, 2009 | Dell Inspiron 600M Notebook
Dell inspiron 600m is extraordinarily slow
it may be due to viruses So please try to Run a good rating antivirus and Antispyware I hope this could help you out. Cheers
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
The Caps Lock Flashing then going off is a power on self-test code. Here is the Dell troubleshooting guide to the issue.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=084A4C3E0A9C9EEEE0401E0A55172321&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
From my experience, if removing al customer removable devices failes to make the system post properly, the motherboard will need to be replaced
Nov 24, 2008 | Dell Latitude D600 Notebook
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
May 25, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
