Question about Seagate U7 (ST360012A) 60 GB Hard Drive
I am trying to install a used Seagate ST360012A 60GB hard drive from a dead emachine c2160 into an HP pavilion 6635 as a slave, but the HP doesn't recognize that the drive has been installed. I adjusted the jumpers for master/slave but nothing happens even when I tell it to detect new hardware. How can I get it to see the drive, and how can I wipe it as the computer it came out of is dead..
  • 734 Answers
Best bet is to put the Seagate into an external enclosure. If it reads there, format to NTFS and re-install in the HP. Also, the HP may have drivers on their site for HD management that you'll need to ever see the drive. Check there for downloads under Storage and the ****** may just wake up without the whole external adventure.
Best Regards
TheSelkie
Posted on Oct 09, 2010
Drive isn't giving me the full 60G
Is the drive new/empty? Try formatting the Drive (Careful, this will delete any data on the drive)
Jan 26, 2014 | Seagate U6 (ST360020A) 60 GB Hard Drive
I installed a new WD 500GB hard drive in an HP Pavilion 513n as a master and have a 60 GB hard drive as a slave for backup data. Both are set to auto in the BIOS. Every time I turn the computer on even...
I think, in BIOS setting your first booting device is the 60GB HDD. change it to HDD0 as 1st boot, CD Drive as 2nd boot and HDD1 as third boot device and it would not ask any error report.
Aug 28, 2011 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Can I replace orig hp ze1115 20GB hd w/60GB hd?
No the bios should be able to read the drive fine. The problem could be with the computer's motherboard. You should check to see if the original drive and new drive is detected in another system. Or you can try accessing them via an external casing / adapter.
May 25, 2010 | HP Pavilion ze1115 Notebook
Jumper settings
If you try to enter in safe mode or at last known config and the laptop reboots or freezes then you need to reinstall the operating system if you want to use that hard drive on hp pavilion a1000n. The laptops have different chipset and XP requires to be the same or similar chipset to boot properly.
Oct 06, 2009 | Maxtor Hard Drive
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Installing Windows XP on new drive in HP a220n
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Jan 03, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Oct 16, 2007 | Seagate Momentus 5400.3 Hard Drive
Seagate U7 (ST360012A) 60 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
