Question about Xerox DC440ST Copier
DC 440 PS machine with printer having problem of NETWORK PRINT CONTROLLER FAULT. In fault code histry it shows IIT-ESS COMMUNICATION FAILURE or ESS- UI COMMUNICATION FAILURE. For this problem i have replaced FIERY with fresh hard disk. I have also checked voltages and connected stabilizer( 2kva ). I have also replaced fresh hard disk 3 times of printer section (FIERY). Ihave aiso reset NVM but problem not resolve. Can anyone Help me .....
Network print centroler fault
Posted on Feb 01, 2011
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
arrwup.gif Spool Initialization
arrwup.gif HDD Initialization
arrwup.gif ESS NVM Initialization caution.gif CAUTION
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
When iam switching on my canon cp 660 model copier while initillazing it shows error E 196
From the service manual:
The communication between the DC
controller PCB and the reader controller
PCB is faulty.
• The communication between the DC
controller PCB and the PS/PCL
board or between the reader controller
PCB and the PS/PCL board is
faulty.
printer1.blogspot.com/.../canon-cp660-service-manual.html
Service and repair manual at above link.
Aug 01, 2010 | Office Equipment & Supplies
Hi We are unable to scan through our fuji printer and the fault error 016-781 comes whenever we try to do it.kindly help
Set "Sub-net Mask" and "Gateway" of the main processor correctly.
From the destination server, check that you can identify the M/C with "ping."
From a Windows95 or UNIX machine to check that the FTP connection to the destination server is possible.
If the machine is a DC 3535, check that the Ethernet Crossover Cable from the ESS to the Network Controller is connected and is free from damage. Refer to the Network Controller service documentation for repair procedures
Jun 25, 2010 | Xerox WorkCentre M-24 Color Copier
Error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error 116-364 and Xerox dealer support doesnt seem to be sure :(
That is a timer fault on the ESS, Netrwork board.
You can try resetting all the connectors on that board. Then power off and on the machine.
If that doesn't work than most likely the ESS board has failed and would need to be replaced.
The ESS is the network control board.
Jul 02, 2009 | Xerox WorkCentre PRO 128 Copier
DC440ST Network/Print controller
When it boots to 70 percent and faults out, one of 2 things.
If you look in the fault codes, or if one is displayed. If it is a 07-11 then you have a bad hard drive in the network area, or as Xerox refers to it as the ESS module, That is the most likely cause.
Secondly maybe the ESS software is corrupted and needs to be reloaded.
I more suspect the hard drive. It's not an uncommon failure.
Nov 09, 2008 | Xerox DC440ST Copier
Help with Xerox DC 440ST Machine
This problem can only be cured by a Xerox engineer or by someone who has access to a Xerox laptop. You have to have a special program called AltBoot to be able to reload the software.
The only other way is to replace the SCSI hard drive in the ESS (network controller unit) with one that has been pre-programmed.
Sep 10, 2008 | Office Equipment & Supplies
386 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
