I have an old Averatec ad135-ec1 all in one desktop pc. When I press the power button, I get power to the hard drive but not to the fans, the processors, dvdrw or the display. The fans work when applied with an alternate power source. The board has no part# ?board number and the serial number appears to have been hand written. Any educated guesses? Prints would be nice or even a board number. hope you can help.
  • 6 Answers
SOURCE: ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
Posted on Jun 03, 2007
  • 3 Answers
SOURCE: My PC Wont Boot Up???
Dear Waqar Khurshid,
What model is your PC and you should do right now is to insert a Bootable CD and troubleshoot the sysem
Posted on Jan 05, 2008
map9966
  • 2351 Answers
SOURCE: pc not on
Please list the name & model number of the motherboard.
M
Posted on Jun 09, 2008
mdsaeed67
  • 849 Answers
SOURCE: asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Posted on Nov 21, 2008
myjosh007
  • 530 Answers
SOURCE: shuttle ab45 v1.2 motherboard, the pc monitor doesn't light up
hi im josh in cebu phils.may i help you. Friend your 478 mainboard doesnt work.? All you have to do is to check the hardware attached on it like hard drive video card memory and most of all the power supply cable.be sure you seated it very well to avoid loose connection. this can cause no display or not working. try to check alson if your pwer supply has enough current to support the mainboard and alson the processor compatiblity with the mainboard. good luck hope i helped you.
Posted on Feb 21, 2009
The power went off on my dell dimension 4700 and i press the power button and it will not come on. What can I do?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect or boot up your hard drive
Test all leads that attach from the ((motherboard to your hard drive)) including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
don
Feb 05, 2011 | Dell Dimension 4700 PC Desktop
The power seems to not be working, the green light is lit on the back of the computer but it doesn't turn on when i press the power button any ideas?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
hope this helps
Dec 06, 2010 | HP Hewlett Packard Pavilion Slimline...
Cpu and power supply fans running, holding on button cpu fan stops a few seconds later. power suppy voltage 4.8 and 11. ?????
One bad lead can cause a computer lots of problems
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
hope this helps
Oct 02, 2010 | E-Machines eMachines Desktop PC
Hi, My averatec is vibrating making weird noises, what causes this?
The only actual components with moving parts are the hard drive and fan(s). Take the side cover off the case and i am sure you will be able to tell which it is. A new cpu/fan heatsink is usually under $20 but a new hard drive could cost you a bit more.
Feb 28, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
Compu is averatec d1002uhce-1 2 month new .... i
sounds like either you have a disk in the cd drive and it won't boot because of it or you have some other device that it is looking to boot from instead of the hard drive.... if not, then you have a bad hard drive. I would first unplug all accessories and eject any discs... Next go into the bios (if your comfortable with it) and make sure the hard drive is in the boot priority... if nothing, then take the cover off and disconnect and reconnect your hard drive. If that doesn't work then you probably have a faulty drive.
Mar 23, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Gateway MT6451 Does not turn on
Probably the mainboard or flaky power supply.
I'd start by replacing the power supply. Buy one you can use in a new machine, though... or "borrow" one from another machine.
Mar 11, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
CD doesn't get out of the DVD/CD driver
Does your operating system recognize the cd? You can check by attempting to browse the contents of the drive. If you can view the contents of the cd then try restarting. If you can't look for a small pin hole in the front of the cd/dvd drive. This is a manual release mechanism. Take a paper clip unbend it and gently push into the hole until the drive releases. Be gentle but forceful if you will.
Jan 26, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
