Manual for RCA 2 Band AM FM Clock Radio "RP5435A
I haved moved to a new state (CA-AZ).  I cant find the manual and I haven't used the machine for  6 months. I have forgotten how to set the time and the two different alarm times. My E Mail addresses are: and
  • 1 more comment
  • Anonymous Aug 26, 2008
    forgot how to set the time
  • mildredann Jan 20, 2009
    lost manual. donot know how to set time.Please send manual to thank you,
    Kelley yarborough
  • Anonymous Mar 07, 2009
    I do not know how to set the time on the clock.
Stitch Selector will not change. How to get it unstuck?
Is it a mechanical (NOT computerized) machine? If so, your machine probably hasn't been cleaned and oiled and the selector mechanics are stuck. Consult your owner's manual, clean and oil as directed using only good quality sewing machine oil and apply only 1-2 drops of oil each place.
Try this ONLY IF IT IS A MECHANICAL MACHINE: gently try to move the selector bar and see where things should move and apply a drop of oil. Then direct hot air from a handheld hairdryer into the mechanics and see if that helps free things up. You may have to repeat multiple times.
Once it is working again, clean and oil every time you change a bobbin, every 8 hours of constant sewing, or every 6 months if not in regular use.
Sep 17, 2015 | Sewing Machines
Science tech 262 manual
Can't find a manual. This is a 76mm reflector on a Alt/AZ mount.
1. During the day, put in the 20mm eyepiece and point to a object around 100 yards away.
2. Focus on the object
3. Align the finder to the object in the eyepiece
4, Set up at night, give the scope time to reach outside temperature
5. Point scope with finder at the moon. (More than half full will be too bright)
6 Use the lowest power eyepiece (highest number) and focus on the moon.
7. You may now use higher power eyepieces to observe.
8. Pointing the scope usually involves loosing 2 knobs to move the scope in up/down and side to side motion. There may be slow motion controls to adjust the scope as objects in the sky move.
Nov 27, 2011 | Optics
I havent used my camera for a few years as the lense was broken. I purchased a new one today, but have forgotten how to use my cameras functions. It is a MINOLTA DYNAX 500si and I am also unable to find...
You can download the manual in two parts.
Part 1:
Part 2:
If you have problems with the above links, try
Mar 31, 2011 | Minolta Cameras
The clutch is not engaging (it seems).. The wheel doesn't turn which in turn means it is not stitching. Haven''t used it in 6 months, but it was fine the last time I used it.
This may seem like a stupid answer but did you push in the knob. If you were winding bobbins last time you used it you may have forgotten to re-engage the clutch.
Jan 12, 2011 | Kenmore 11101 Mechanical Sewing Machine
No manual came with our new bosch avantixx 6 washing machine
Unfortunately you cant download manuals from their web site so heres their phone number. Hope this helps you.
BSH Home Appliances
5551 McFadden Ave.
Huntington Beach, CA 92649
Telephone :1-800-944-2904 Fax :714-901-5360
Jan 10, 2011 | Bosch Washing Machines
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
You may need to use a different server if not in CA.
Jul 08, 2009 | LG Computers & Internet
Motor centrifugal switch bad
You cant get the switch seperate for that motor, you have to get a whole new motor.
Oct 31, 2007 | Kenmore 98702 Stacked Washer/Dryer
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual, pg 9, and this is their solution.)
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Daylight savings time adjustment
Go to:
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source:
2,870 people viewed this question
