Question about Gateway HD1900 19" Monitor
Looking for the gateway hd1900 lp1925 drivers, any ideas?
After changing the resolution in Windows, press the AUTO button on the side of the monitor. This will optimize the monitor to match your resolution.
Posted on Oct 16, 2012
  • covinaca
    covinaca Oct 16, 2012
No ideas here, but if you find/found them please link. Thanks!
Posted on Oct 05, 2011
What connections are required
Make sure the monitor works on a friend's PC using the DVI... let's not go backward to VGA when DVI is available on both the PC and monitor. If the monitor works, install the driver and reboot. It should work for you too.
Jun 19, 2014 | Gateway HD1900 19" Monitor
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
I have a web cam built-in to my gateway need to get it workin again any ideas how to istall it?
You can download drivers for the webcam at:
http://support.gateway.com/us/en/product/default.aspx?partNumber=1015608R
There are two different models of webcam for that particular model unfortunately, so you either need to try them until one works, or download the hardware detection tool at the top of the page.
If you just need the bundled software, click the application tab on that page and you can download that as well.
Please leave feedback if this was helpful. Thanks.
Mar 17, 2011 | Gateway M-6843 Notebook
Display comes on, says "Digital," then goes black.
I'm not sure what's happening, but here are some questions to ask yourself:
-Are all the cables properly connected? Monitor to computer, monitor to wall?
-Is your graphics card properly inserted in your computer?
-Does the display work when plugged into a different computer?
-Is the computer plugged in and turned on?
There's a troubleshooting section in the user's manual, found here:
http://support.gateway.com/s/Manuals/Monitors/8513019.pdf
Mar 07, 2011 | Gateway HD1900 19" Monitor
Monitor goes black, then after being off for a while, will comeback on for a few miutes
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 08, 2011 | Gateway HD1900 19" Monitor
What is the most likely cause of the problem of a gateway HD1900 monitor fine works for 5 minutes when powered on then goes dark but imagine can be seen in background
The back lighting fails - the CCFL tubes lose their power most likely because of a bad contact.Open the case of the monitor and press all wires firmly in their connectors.
Sep 04, 2010 | Gateway HD1900 19" Monitor
The power button keeps blinking every 2-3 seconds and the screen is black and wont turn on
It sounds like it is in "sleep mode"
Try pressing any key on the keyboard and see if it wakes up.
Nov 04, 2009 | Gateway HD1900 19" Monitor
Gateway HD1900 19" Monitor Logo
1,067 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
