Question about Canonical Ltd. Ubuntu
How to establish a network connection using ubuntu as server and windows xp as clients?
    Scholar:
  • 97 Answers
Make sure that you have samba installed, that will allow you to share folders as shares that Windows can see.
If you want to get tot he CLI on the ubuntu server from the XP machines, just download PuTTY (just google 'download putty'), and then you should be able to SSH to the ubuntu server.
Hope that helps!
Posted on Oct 17, 2010
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
Ubuntu 8.04 x64 not connecting
Ubuntu has his own print server. When you click on System/Administration/Print (not sure, because I use the French version :Impression), it opens a window. Then you select Go to the server (again, something similar to that choice), and you can configure the options for the server.
Nov 21, 2008 | Edimax PS-1206U (PS1206U) Print Server
Wyse S30 thin Client with Ubuntu
You might find an answer for this Ubuntu problem, in the Ubuntu product.
Try posting your question there if there's no existing one.
Good luck.
Nov 27, 2007 | Neoware Systems c50 Thin Client Network...
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Canonical Ltd. Ubuntu Logo
107 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
Dennis Gutowski
Dennis Gutowski
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
