I HAVE TRIED TO USB PORT BUT IT IS NOT DETECTING IN SYSTEM.so ihave broght new firewirecard,but the same problem assisting,so kindly get me correct solution as soon as possible
IN PC it is asking drivers to install...with camcorder i didnt get drivers.so how to get drivers and install in PC
Thanks and Regards
D.PraneethI HAVE TRIED TO USB PORT BUT IT IS NOT DETECTING IN SYSTEM.so ihave broght new firewirecard,but the same problem assisting,so kindly get me correct solution as soon as possible
Thanks and Regards
D.Praneeth
You can't post conmments that contain an email address.
Our model numbers in South africa are nv-gs47 etc. I know that all the new models like the pv-gs29 you dont have to use the firewire port on the camera, it is better to use the usb port because it is usb 2 you can do video streaming. The usb port is also more reliable than the dv port.So just check in the manual if this unit can use the usb port instead. i am more than sure it can.
Yes ... you need a firewire port if you want to capture your video to the PC....search online for a firewire pci card or if you have a laptop you may have one already installed if not you can purchase one in pcmia format to capture your footage to pc.
You can connect camcorder to the PC by fireiwre (IEEE1394), if you don't have firewire controller on PC, you can buy one. It is not expensive and usually comes with the cable.
From the online specs it appears the this camera connects via Firewire, which is a different connection than USB. If you do not have a Firewire connection you can buy an add-in card for your computer usually for less than $20 online or probably more at a Best Buy.
For a desktop computer, you need something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815124003
For a laptop computer, you need something like this depending on the type and availability of your expansion slots: http://www.newegg.com/Product/Product.aspx?Item=N82E16815124014
I have the same thing..bought it clearanced...thought it was capable...IT IS NOT capable of Computer upload. Check your manual there are two similar models the manual refers to gs59, gs 39 on page 7, and 8. THis model is not USB compatible..the firewire is just for service technicians It simply is not computer ready...unfortunately we are stuck!
try connecting the camera to the computer through your firewire then go to if you have windows xp click start then click on control panel, then click on printers and other hardware, then click on scanners and cameras, then below the back icon will be add an imaging device and with the camera hooked up to the computer through the fire wire and the camera turned on click the add an imaging device. then follow the prompts in the installation wizard. if this dont get your camera back on line then you will need to find the drivers and program for the camera. you might find it at the panasonic web site just check for down loads for the camera.
Thanks and Regards
D.Praneeth
