Question about Vacuums
Where is nuvac vacume clener service center in raipur
  • 377 Answers
I googled the name and found information at this URL http://www.google.com/search?hl=en&biw=1409&bih=943&q=nuvac+vacuum+repair+in+the+US&aq=f&aqi=&aql=&oq=&gs_rfai= It does not look too promising. Lots of references to India. Hope this helps. Paul
Posted on Oct 09, 2010
Users manuel vacum fantom model fm722c
Appliance Troubleshooting Appliance Service Manuals Service Updates try this website, or you can type in user manual with your model # at about.com or wow.com
Apr 12, 2014 | Fantom Vacums Vacuums
I was lifting off the canister, and now there is a connector sticking up from the base. It looks like a phone jack connector. I can't reattach it. It's right in the center of the bottom of the cannister....
If the connector does not move when you gently push or pull it when you slide the canister back on the vacume it should go in place. If it is on a short piece of wire you have to gently fit it in to the hole on the other part of the vacume
Mar 11, 2011 | Bissell 3750 Lift Off Bagless Upright...
We have a kenmore canister vacuum and it runs but when turn on the rug clener brush the brush will not run we then put on small brush head and that will work
If the power head motor runs, but the brush doesn't turn, then the belt is broken. Replace the belt and it should work.
Nov 29, 2010 | Kenmore Vacuums
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
Vacum bags
The vacuum that you have is over 10 years old. You can no longer get the bags directly from Bissell but if you call a authorized service center near you, they may still have bags that will fit your vac. So the answer to your question is yes....they use bags. Good luck!
Aug 03, 2009 | Bissell 3065 Power Partner Vacuum
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
REPLACEMENT FILTERS FOR THE POWERFORCE 6 BAGLESS VACUM.IS THERE A BISSELL STORE IN THE DETROIT MICHIGAN AREA I CAN FIND BISSELL BELTS FILTERS ETC.
Here are Bissel's numbers, they can tell you who to contact.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Aug 10, 2008 | Bissell Vacuums
Instruction manual
Go to www.fantom.com. In Support Wizard, type in your model number. You'll see a file called Product Manual. click it to open and print.
May 22, 2008 | Fantom Vacums FM741 Twister Bagless...
I work for a company and we have bought about 25 hoover upright vacums since november of 2008 from HD supply and we are to refer to hoover for manufacturers warranty. We have a vacum that needs a bag...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=560323
Generic problem for all Vacuums
Posted by dmoses96 on Apr 30, 2008
I work for a company and we have bought about 25 Hoover upright vacuums since November of 2008 from HD supply and we are to refer to Hoover for manufacturer’s warranty. We have a vacuum that needs a bag replaced under warranty.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would say you need to call the Hoover manufacturer and they would direct you to a local factory authorized vacuum dealer for the bag replacement – typically the bags and belts are considered wear items and are not covered under the factory warranty but I feel that it is still worth a phone call to see if Hoover Co will replace the bag for you. It will be up to the Hoover Factory Service Center, Question…. Is it for household use or commercial use? So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
