Question about JBL 6-1/2\ Round Coaxial Speaker By Prospec Electronics" Speaker
I have a pair of jbl mr series 925 pa speakers and both have lost the use of the high and mid frequencies. The lows work find but it is just weird that both went out at the same time. Is there any way that I can repair these speakers by myself? Miss the sound.
5 Suggested Answers
jhinsincity
  • 616 Answers
SOURCE: picked up a pair of jbl tlx 171 cabinets. shopping
Contact JBL
Posted on Jan 21, 2010
technical114
  • 1851 Answers
SOURCE: my JBl PRX 515 has
Your speaker is an active one. This means that it has indepented amplifier for low and high frequencies. So maybe the woofer (low speaker) is still active but its amplifier is defective. In order to make things more clear take a look at this block diagram to understand the signal flow:
I suggest you to unscrew the screws at the back panel and eject the whole electronics from the inside:
Take care the cables that connect the electronics with the speakers. If it's easy mark what goes where and unplug these cables. Now with the electronics on the table try to locate fuse(s) that may have been blown; since you don't smell burned components, fuses is the most common problem. Replace any blown fuse with the same one and put things back in the proper order. In case that you don't locate any fuses the problem is at components and I can't be sure if you can manage replacing components.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 13, 2010
SOURCE: Hi, I have 2 JBL
i had to buy a complete amp and replace the old
Posted on Oct 07, 2010
  • 14 Answers
SOURCE: 4 out of my 5
Before you blame the speaker one simple test needs to be made, if you have not done so already.
If one remaning speaker has full volume output, swap one of the 'defective" speakers to that same channel the "good" speaker was attached to, and see if the output drops.
Posted on Nov 23, 2010
My JBL soundbar starts making heavy bass sounds 10 minutes after I start playing music. how can I sort that?
Front and surround power amplifier section circuit fault. Mid and high frequencies loss. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts
Nov 12, 2016 | JBL Audio Players & Recorders
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
How do i link 2x tr125 jbl speakers to 2 mr922 jbl speakers
The connections are pretty straight forward, but it will depend on what amplifier you're driving them with. Normally, I'd connect the two TR to one side of a stereo PA amp and the two MR to the other side. All four cabinets are rated at 8 ohms, so running tow parallel per side would give you a 4 ohm load on each channel which would be a common load for most stereo PA amps.
However all this would depend on your gear and what you need to accomplish. If what your question really meant is how do you connect all 4 to one channel, you can't as in most cases the total impedance would be too low and you'll fry your amp.
If you can be more specific about your system we could be more helpful.
Mar 17, 2015 | JBL Music
My JBL 510 high end pops intermittently
Damaged component/s at its main power amplifier stage circuit. Leaky capacitor/s can cause this fault, and locating the exact one is a skilled work indeed. It will be best to contact any service technician. This is not a user repairable fault. If you wish to get some details, visit the site linked here.
Electro help
Nov 15, 2014 | JBL EON 510 EON510 Powered PA Speaker
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
How do change the woofer in theis speaker
are they still under warranty?
Worth checking into ... JBL has a good warranty program for this series and local authorized repair centers ... if you are under warranty you could have a fix for free in about a week ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 22, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL 6-1/2\ Round Coaxial Speaker  By Prospec Electronics" Speaker Logo
115 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
