Question about Sony KP-51WS500 51" Rear Projection Television
WE have a 51 in sony rear projection tv that needed the convergence chips changed. I did that, but after getting it back together it shuts off and the front blinks 8 times. Did I screw something else up in it when it was apart? Any ideas on what to do next (besides kicking it to the curb)??
  • barbjsteiner Oct 10, 2010
    Thanks for the help. We got a new 1 today. No more SONY for us! Sounds like they are lemons from reading other things. Thanks again. (I can't return the chips/ I had already soldered them in.....)
    Barb
    President:
  • 2,777 Answers
It sounds like it had mainboard problems probably in addition to the IC... Can you still return those convergence chips? I hope so, I would recommend you just replace the unit, it may have even more problems. A lot of times when convergence ships go it takes other components with it. Will keep researching this for you though.
Tim
Posted on Oct 09, 2010
  • Tim Grayson
    Tim Grayson Oct 10, 2010
    Glad to hear it! My pleasure to help. If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
I'm getting a curved(fisheye) picture with the three colors not lining up.
This kind of picture appears due to failure of convergence output section in rear projection tv, please check convergence output chips and replace them (tv has two chips of same number)
Let me know if you have additional question.
Thanks.
Feb 03, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony 51" projection tv standby light blinks 6
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 15, 2010 | Sony KP-51WS520 51" Rear Projection...
Colors run together,picture out of focus
Your tv needs the convergence re-aligned, look into the owners manual or call the manufacturer to get a walk through of how to do it. It will be in the menu of the tv under convergence.
May 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Sreen pulled in on top and bottom
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-61HS10 61" Rear Projection...
BAD PICTURE, DISTORED, MOSTLY ON THE EDGES, BUT THE BLACK LINE ON TOP IN HIGH DEF CHANNELS IS NOT STRIGHT ACROSS, IT BOUGHS DOWN LIKE A "U" SHAPE
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 15, 2009 | Sony KP-51WS520 51" Rear Projection...
Red convergence problem
  • Screen looks 3D
Apr 07, 2009 | Philips 51PW9303 51" Rear Projection...
The screen is just blue... apparently, the red ad green lights are blown. How do I rectify this situation? Sony rear video tv kp51ws500
Problem : Convergence Chip Failure ( common problem )
  • Screen looks 3D
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.They have put together a kits for most models. If you don't see a kitfor your set send them a quick note and they will put one together foryou. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony TV rear proj works but color is blue
  • Screen looks 3D
Solution :
Good Luck.
Regards
Arjun
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP51WS500 Rear Projection TV,Convergence Problem
  • Screen looks 3D
Dec 29, 2008 | Sony KP-51WS500 51" Rear Projection...
Color distortion and arched picture
  • Screen looks 3D
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
