Question about Garmin Quest GPS Receiver
Do you know where you got your battery?
My Quest has been left out in my hot car too many times, and needs to be replaced, but I can't find one for it.
Thanks,
Ed
eflicek@yahoo.com
  • 24 Answers
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devicesDo you know where you got your battery? - 2_bing.gif, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
After plugging the new battery in, you may want to use a small dab of glue to secure it to the back side of the unit like the original battery. Reassemble the unit, reversing the process with the front and the back. The Quest units have a rubber sealing gasket between the two sections. Be sure you inspect that for kinks before tightening the 6 small screws. I would suggest the screws be tightened down gradually so uniform pressure will be applied to the gasket. I would tighten one screw down partially then move to the opposite side and criss-cross the unit until all screws are snug. Again, inspect the gasket for proper seating and you are done.
Posted on Feb 01, 2010
We just ran into battery problem. it swelled up and warped the
case. The usb port stopped working. When we opened case to
find if we could get a battery we spaced the usb connector up
so that it hit the contacts on unit and usb worked so we at least
didn't lose info. Garmin stated that if usb didn't work they could
not grt data from unit.
Posted on Jun 16, 2008
1997 nissan quest is running hot. changed the thermostat. but it will start lurching once it starts running hot.
Many things can cause this but check the radiator. It could need cleaned as in rodded out. Could be a blown head gasket or timing could be slightly off just enough to overheat it.
Apr 06, 2010 | 1996 Nissan Quest
Nissan Quest 1996 won't start. Battery good.
tap the starter at the same time turning the key. if it starts ,replace starter.
Mar 14, 2010 | 1996 Nissan Quest
My 1996 Nissan Quest car stereo stopped functioning
YOU MAY WANT TO TRY DISCONNECTING THE BATTERY OVER NIGHT I KNOW IT WORKS ON FORDS
Mar 04, 2010 | 1996 Nissan Quest
Nissan quest electrical problem
Professional repair short use a tone ringer,infrared sensor to locate the trouble spot.
The quick way to isolate short is to test one circuit at a time.
Check for hot spot on the wiring.
Check for melted plastic.
Quest has a track record of bad grounding wires between engine to frame and engine to transmission.
I would check on the these grounding cables.
Replace them with 14 G wires.
Add three more wires from the neg. battery terminal to frame,engine and body of the transmission,
Nov 06, 2009 | 2004 Nissan Quest
Where is the flasher relay for an 01 Nissan Quest? not certain where it is and which one.
M11 location near left side of steering wheel near the middle of the column
Combination Flasher unit.
3 wire Color
Orange
Purple
Red
let me know
Sep 20, 2009 | 1995 Nissan Quest
Yesterday, my 2004 Nissan Quest had the front end bushings and control arms replaced. The car still has a "knuckling" noise when I'm making semi-hard left or right hand turns. Forget about hard turns!! ...
it usually does but you have also an intermediate shaft that connects steering column to steering rack, I know those at times can cause the exact noise you describe although what you replaced usually does.
Sep 02, 2009 | 2004 Nissan Quest
Wont start does not click at all just put in a new battery I left the lights on for several hour came back out to go some where and it would not start after several attempts to have it jumped i took the...
Sounds like your alternator might have gone bad. I don't know how long the time was between the two batteries going bad but your alternator is what keeps your battery charged. If you haven't left any lights or anything on with this second battery and nothing is shorting out causing the battery to lose all it's power, your alternator is shot and needs to be replaced. The good news is that they can test that for free at your local auto parts store and tell you if you need to replace it or not. Let me know if you have any further questions and thanks for using FixYa!
Jul 08, 2009 | 1996 Nissan Quest
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Garmin Quest 1 won't start up
My Quest had the same problem, I took it apart to see what I could see, 6 black screws on the back. What i found is that if I unplugged the battery and plugged it back in it would power on one time but not again. So I just left my battery unplugged and it works great from the car cradle all of the time. The clock resets but when it links to the satellites it gets the correct time again. Hope this helps you.
Jul 08, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
248 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
