Question about HP Pavilion a1540n PC Desktop
I am not able to get the driver for internet on my Pavilion a1540n desktop
  • 30 Answers
See product code from back side of the pc, there is S/N no. and P/N no. copy the no. and go to the hp site use the s/n no. and p/n no. select then system and download the driver .........
Posted on Oct 09, 2010
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
The TS-H652L drawer opens and will not close. Need a driver perhaps??
Drivers should not impact the drive not closing. This issue is a hardware issue. Good thing is you can order a new dvd+dl burner sata or ide off of newegg.com for under $35
Aug 28, 2011 | HP Pavilion a1540n PC Desktop
My hp a1540n will flash the blue light once but will not do ANYTHING else.
Do you still have original cds that came with your computer? The bluescreen is an indication of a serious issue with your computer that may require reisntalling everything on the computer from the original cds that came with it.
Apr 13, 2011 | HP Pavilion a1540n PC Desktop
We just got an HP Pavilion A1540N from my cousin, we are trying to boot it up and it beeps and the monitor turns on but goes right to sleep.
Will need the beep sequence the amount of beeps. The beeps lets ya know that there was something wrong in POST. Most likely cause would be the video card but need the beep sequence to be certain.
Mar 26, 2011 | HP Pavilion a1540n PC Desktop
My hp pavillion a1540n won't boot up. The power button is on but no boot menu on the monitor. Monitor is blank
I suggest you check the Power Supply. Bad Power Supply, weak Voltage power rail.
1) ALL the LED lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is. (Older one's use less)
The HP Pavilion a1540n specifications state it uses an AMD Athlon X2 4200+, processor.
(2.0GHz. Dual Core. Built upon the Windsor Core. Uses a Socket AM2 processor socket)
HP Support > Pavilion a1540n desktop computer > Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00679533&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3184140&lang=en
Can use up to to 89 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Windsor.22_.28F2_.26_F3.2C_90_nm.29
Enough power for the LED lights, and fans, but Not enough for the Processor.
No Processor operating, No computer.
No computer, No Signal to the monitor.
(Video signal)
The Power Supply used is an ATX style, and 300 Watts.
A computer only uses the power it needs, and No more.
If you install a Power Supply with more Wattage than the original, it will be fine.
Jun 19, 2010 | Computers & Internet
Video on my HP Pavilion a1540n is broken
Yes you put in the video card and the default is lowest resolution and is usable without a driver, install driver then reboot and you have your new video card to set up the way you want.
May 15, 2010 | HP Pavilion a1540n PC Desktop
Hp pavilion a1540n does not boot, fan turns on high, and beeps once every +/-5 seconds
Sounds like a memory fault, try removing 1 memory at a time, and restart. might help, try each memory by its self to indentify the bad card.
Dec 01, 2009 | HP Pavilion a1540n PC Desktop
I can brows sites on my pc but when i try to
This might because of the your internet speed, if the downloading speed is low then this tends to happen very often, use a down load manager while downloading might just help you.
Jun 12, 2009 | HP Pavilion a1540n PC Desktop
HP Pavilion a1540n  PC Desktop Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
