Question about Maxent MX-50X1 50 in. Plasma Television
I have a Maxent 50 " plasma TV that I am trying to sell. Prospective buyers are asking me questions like "is it 720 vs 1080 Pixels"??What year is it?(I think 2007) How do I find out? I lost the operation manuel. All I know is the Product name says mx-50X3 and model # P500550HM8. Is there a way to find out a fair asking price? Thanks so much
5 Suggested Answers
SOURCE: Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Posted on Mar 16, 2008
Nickstar19
  • 417 Answers
SOURCE: 720 and 1080 resolution
depend if your TV dos 720 & 1080 ill look into this more for ill get back 2 u soon
Posted on Aug 16, 2008
SOURCE: Maxent MX-42VM10 42 I have sound but no
i can get sound but no pic can u help 42vm
Posted on Aug 23, 2009
caroldon
  • 17130 Answers
SOURCE: Maxent MX-50X3 picture started to shake for 30-40
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time. Based on the above method you must be able to locate the area of fault and solder the sections.
Posted on Oct 18, 2011
I have a Maxent 50" plasma TV model # P5000550H9
Here is a link to the RETREVO site which has a PDF copy of the complete User's Manual for the Maxent 50" Plasma TV:
http://www.retrevo.com/support/Maxent-MX-50X1-TVs-manual/id/278ag121/t/2/
Just use your mouse to click on the link, which is the underlined and highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
When you get to the RETREVO page, click on the blue DOWNLOAD THE DOCUMENT (2.64MB) button on the left hand side of the page under USER MANUAL FOR MAXENT MX-50X1.
Once you click on that and get to the next page, don't bother typing your email address in the empty box, it's not necessary.
Just TYPE THE NUMBERS SHOWN BELOW into the second empty text box.
Then click the red DOWNLOAD NOW button.
When the computer asks if you want to open or save the file, CHOOSE OPEN.
If it does not open, then you may need ADOBE READER installed on your computer to read the PDF document.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 26, 2011 | Maxent MX-50HPT51 50 in. Plasma TV
My 42" Vierra 1080 plasma
The pixels in the screen are commanded by a buffer board . This board connects to the screen with the help of a wide flat connector - in your case this command circuit appears to be faulty: either the buffer circuit is failing and the entire buffer board will have to be replaced ($250 part and labor from a pro) or the connection itself appears to be slightly out of line so when heated the contact is lost and the pixels get stuck (in that case the tv will have to be completely dismantled and all the contacts to the plasma panel reseated - $200 in labor).
Ask a quote around and select the cheapest repair shop you can find.
Apr 17, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Can I change the resolution on mx-42vm11?
Resolution is definded by the input. If you are receiving an HD signal it will display in either 720 or 1080.
The display is only as good as the input.
Dec 29, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a skinny line going down my tv it looks like a laser beam
Sounds like you have a row of pixels that have failed. Check and see if it is under warranty, If not it can be very pricey to repair.
Apr 08, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Dec 11, 2008 | LG 50PC1DR 50 in. Plasma HDTV
I have a Maxent MX-50x3 50 inch plasma. built may 2006, bought at best buy in april 2007. Allways has occasional red pixels randomly when switching inputs. Now we have vertical red lines and pixels and...
if you take the back cover off the tv, you will see in a white screw in almost every board, those are called pot. (potentiometer).
if you can get to meter the Ve. Vs. and Vset. start to screw or unscrew those white screw according to what the label says.
usually the ones who gives you the blue and red dots are the white screw on the right of the center panel, and the one on the right of the right panel right under the metal thing to hang on the wall.
Aug 20, 2008 | Televison & Video
50PX1D-UC
This tv is capable of working with 1080P. Depending on what you are hooking up to it will depend on if you get that resolution.
Dec 12, 2007 | LG 42PX4DR 42 in. Plasma TV
Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Maxent MX-50X1 50 in. Plasma Television Logo
97 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
