Question about Refrigerators
Amana refrigerator model #atb2136ar:popping sound, then a burning smell, and then the light bulb went out.
  • 3,530 Answers
A popping sound is a normal sound on frost free refrigerators. A burning smell could indicate a lot of things, a dust build up on the compressor. In your case, since the light went out, it is possible that an electrical wire got damaged.
I suggest to get have a technician check this for your for your own safety.
You can also check on this link.
Posted on Oct 09, 2010
Installed new brake lights, now smelling burning plastic...?
I would say you have the incorrect bulbs in them.
Mar 11, 2017 | 1997 Toyota Camry
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
Aquarium light model #1628626
Yes, they are fire hazards. Mine made a popping sound, then I smelled a rubbery smell, I quick unplugged it and tossed it.! see recall notice, mine was not even one of the model #'s but it was a "Discovery Kids" silver framed Marine one. see link
http://www.aboutlawsuits.com/discovery-kids-lamp-recall-fires-smoke-8194/
Apr 26, 2012 | Toys
Model ATB2136ARS My refrigerator is working just fine, but it keeps making a clicking noise. The clicks are becoming more frequent.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 18, 2011 | Amana ATB2136ARS 33" Top Freezer...
I have a GE Model number GSS23WSTASS side by side refrigerator and when I open the door, it smells like something is hot or like something is burning. What could this be? I doesn't smell while the doors...
The first thing I would check is the light bulb and light bulb diffuser.
If the bulb was replaced with either the wrong shape or the wrong wattage (higher) the bulb could be touching the disfuser (shade) or some other part of the mount.. if the bulb is too high of a wattage the heat could damage the mount and shade..
I believe that is a 60 watt appliance bulb. (soft white)..
Also this model uses a "special" light bulb for the defrost cycle. If you unit is very frosty on the inside.. frost build up could cause the fan to stop running.. you should hear a fan running when you open the freeze side. If that bulb was burned out. you would have a frost problem regardless.
You didn't mention which side smells like this.. chances are it's the fresh food side.. again.. check the bulbs..
The last thing would be a circuit board in the door.. but doubtful.. go for the simple stuff first.
Even a wrapper or food item may have become lodged between the bulb and the shade/difuser.
Mar 11, 2011 | Refrigerators
Freezer temp seems to be fine but fresh food area not cold
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 01, 2011 | Amana ATB2136ARS 33" Top Freezer...
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I was watching tv and all of sudden it was a popping sound and the tv went dark.i unplugged it,and it was a little bit burning smell.
Well best case is that the bulb burnt out, replace the bulb and clean out cooling fans and hopefully it should come right back on.
Apr 24, 2010 | Televison & Video
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
