Question about HP Computers & Internet
I want to add the hp 1270i to my hp computer how do i?
  • 60 Answers
In order to replace the optical drive on your PC, you would need to first remove the side panel (opposite side that the motherboard outputs are on). Next, you disconnect the cables for your existing drive and motherboard (unless the drives are the same type of connection) install the replacement optical drive, connect the cables the the drive and your motherboard. Replace the side panel and you are done.
Posted on Oct 09, 2010
I have a HP pavilion a1700n and the dvd quit working. I bought a hp dvd/cd writer 1270i. This unit has SATA connection. I noticed that my a1700n has an unused SATA connector and there are three unused...
A SATA hard drive needs to be pugged into a SATA port on the motherboard. They're the "L" shaped ports. They look like this: moondogwst75_2.jpg
The little blue ports. The hard drive should have come with the appropriate cable. Other than that, just plug in a SATA power connector to your hard drive and you should be golden. Hope this helps!
Aug 27, 2011 | HP Pavilion a1700n PC Desktop
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
I can't get my brand new HP dvd 1270i 24X Multiformat DVD Writer,to load the nero9 Essentials software/Drivers and manuals and LightScribe to install.Also no Windows Vista will not load any workable...
You've got a toughie here but I'm wierd enough to either answer corretly or you trash my ratings.
So. here's the sense of it Load all W7 drivers possible for your stuff. It was all built off Vista anyway. and If you're not running Vista Ultimate 64 Bit while you're messing around, you should be ballsy enough to ask for the consultant pre-activated disc of same so you can play right or quit bitchin'
Oct 02, 2010 | HP Computers & Internet
Recently I purchased a HP dvd 1270i DVD writer through your company. I need an installation diagram on how to install. There is a steel plate covering the buttom dvd bay that must be removed. Also, I...
There is a tutorial here
http://www.youtube.com/watch?v=lIG7P7r2jGk&feature=related
The ddifference is thet your DVD is a SATA one but the process is the same. (no jumper pins)
If you have the same power leads as shown in the vid you will need get a a covertor cable.
Aug 12, 2010 | HP DVD±RW Burner
How do I add additional music selections to my HP Photosmart 380 computer software program?
This is not a printer problem. How do I add music to HP Photosmart Premier software?
Jan 06, 2010 | HP Office Equipment & Supplies
Hp psc1350 all in one the printer was unplugged and when i plugged it back in the computer did not find it. the printer dings everytime i try to print
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=306884
Try downloading the drivers and software from HP.
Uninstall your printer from 'Printers & Faxes'.
Remove your printer from ' add & remove programs'.
Remove your printer from 'Add & remove hardware'.
Disconnect your printer from your computer.
Reboot your computer.
Install the downloaded software from the HP site.
Hook up your printer to your computer.
Your computer should find the new hardware and install your new software.
If not, re-install downloaded software from HP site manually.
Jul 19, 2009 | HP DeskJet F380 All-In-One Printer
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
Hello My Name is gloria aguirre montenegro and I own a hp office jet 5610v all in one I was trying to install the software on to my other computer but it is not copying.I noticed the cd loos like it has a...
go to this link to download the driver so you can install it on other computer:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-43586-1&lc=en&dlc=en&cc=us&product=441125&os=228&lang=en
Just right click your mouse button hold it and copy the above link, then add to your browser window and past, then read down a little bit and hit the download button and chose were to put, copy to cd then add to other computer. Note that this is the HP site so you might want to add this to your favorite's for future use!
Dec 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer
please uinstall and re-install the entire s/w.... note : plug in the usb only when prompted.uinstall the s/w after unplugging the usb. uninstallation----- go to add & remove program....remove all the printer related s/w in the list. c:/ - program files - util - ccc - HP/Hewlewtt Packard - Digital imaging(could be in hp or in hewlett packard)-uinstall/remove NOTE: if u r not an hp computer user delete the entire HP/Hewlett Packard file.Do not do so if the computer you are using is of hp. open start - run - type regedit - enter-registry editor opens - HKEY_LOCAL_MACHINE-software-if u r not an hp computer user delete the entire HP/Hewlett Packard file.Do not do so if the computer you are using is of hp/Digital imaging(could be in hp or in hewlett packard)-uinstall/remove restart the computer give a print command
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Computers & Internet Logo
271 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
