Question about Hitachi 55HDT52 Plasma Television
Power supply has 5.8v, 14.8v, 24.9v , but missing 80v ???
  • ta6491 Oct 09, 2010
    extraordinary
    2400/100v 2caps replaced, diods good and wire disconnected. where get scematic diagram?
  • Hitachi Master
  • 11,800 Answers
If it's completely missing then either the Y-sus board is fried or the filtering capacitor has failed the big way. You should be able to see that just by looking at it - the capacitor will have its casing deformed. Simple test - replace the capacitor and try it. If it's the same then disconnect the wire leading to the Y-sus board and try again - if it's dead then the rectifying diode must have been fried, replace it.
Posted on Oct 09, 2010
    President:
  • 2,777 Answers
Sounds like the power supply has failed then, 80v is the main power of course, so without that the power supply is more or less dead.
Thanks
Tim
What problem of sharp crt 21v-w70m dropping voltage in b+ to 80v when i turn on
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
Jul 24, 2014 | Sharp Televison & Video
Why 2004 honda shadow sabre flywheel rubbing stator?
Wow,- how do you know, I never heard of that.
Maybe if one of magnets is bit off. Do you have 80V AC from stator wires. (Three wires coming from left case cover). Measure between two with engine on must give you ca 80V. This way you know Stator is o.k.
May 14, 2014 | Honda VT 1100 C Shadow Motorcycles
DRIVER DC 80V IC3645SR7W455N8
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Nov 18, 2012 | GE EasyCam Webcam
My power will not turn off and the blue light stays on. I get no picture or sound. PLEASE HELP!!!
First of all you have to check the Va - 60V and Vs - 80V voltages at the power supply point. If any one of the voltage is missinig there are two possiblities for that. One is the power supply itself and the second one is the sacn drive modules for X and Y. If the scan drive modules are faulty then the or short then the Va Ans Vs voltage from the power supply will drops.you have to measure using a multimeter is there is any short circuit in its power supply in put point. When the voltages from Va and Vs point are missing then this will indicated by the blinking of power light. To rectify the problem you need a good knowledge in electronics. Aslo need the necessary equipments for measuring the voltage at different points
Nov 10, 2011 | Hitachi P50T501 50 in. Plasma HDTV
Panasonic DMR EH50 will not power on. All
REPLACE THE PSU REGULATOR- STRG6353A
Aug 01, 2009 | Televison & Video
Hitachi PDP 55HDT79 got no picture
that power supply is a switch mode power supply,which means it looks for an input signal to turn on.
that signal comes from the main pc board.
if there is excessive current draw,it will shut down.
check the input,and the screen circuit it is driving
May 13, 2009 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Crown PSA-2 power amp. Right after turning power on with volume controls all the way down, the amp continuosly thumps the woofers (alternating from the right to the left. This just started to happen. No...
Hi! The thumping motion is usually caused by faulty cross-over voltage biasing. What this is is simple; Power amps of high wattage are usually constructed of two similar but opposite polarity amplifiers ;one drives the top (positive) part of the sinusoidal and the other drives the bottom.
The simple causes that need to be eliminated are
1) Earthing :-check earthing to ensure no earth loops
2) Check the Power fuses:- usually, the supply of power to only one part of the amplifier causes thumping motion. The power section in these designs have a positive and negative polarity eg.=80V-0V-(-) 80V
3) Disconnect the speakers and check the power supply Voltages across the output stage sumettry for more details visit
http://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
Dec 02, 2008 | Audio Players & Recorders
B&W PV1 Subwoofer
Make sure that your amp is putting out proper signal to the sub woofer.
If the feed from the amp is okay, the power amp and our the power supply in the sub woofer may have become defective. This will require to be serviced.
Jerry G.
Jun 13, 2008 | B&K AV 125.7 7-Channel Amplifier
Hitachi 55HDT52 Plasma Television Logo
140 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
