Portable device will not open model YP_K3 - Audio Players & Recorders
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Go to the following page on Samsung's website and select your EXACT model number - the part that comes after the YP-K3 - if they still have the software, you will find it there:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=audiovideo&group_cd=&type=mp3players&type_cd=&subtype=flashmemory&subtype_cd=&model_nm=YP-Z5ZP%2FXAA&dType=D&vType=L&mType=&model_cd=&menu=&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K5&isEqualsY=
Posted on May 30, 2008
  • 21 Answers
SOURCE: how can i transfer files from pc to yp-k3
If you have Windows Media Player, just plug it in using the proprietary usb cable, and it should show up in Media Player. Click the Sync tab, and simply drag and drop.
Posted on Oct 13, 2007
SOURCE: Samsung YP-K3 Playlists
the only way to create a playlist is using the samsung media studio.....
it's better and easy
Posted on Jan 30, 2008
SOURCE: MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Posted on Feb 13, 2008
  • 6 Answers
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Posted on Jul 11, 2008
SOURCE: device not detected!
Well I was facing a similar problem and none of the above mentioned solutions worked really for me until I noticed that the device uses MTP (Media Transfer Protocol) for data transfer and isn't just a mass storage USB device like most other MP3s.
The above blabbering aside here is the solution:
1. Download Windows Meda format 11 SDK and Media Transfer Protocol (MTP) Porting Kit from the Microsoft Website.
2. Install the above mention software plugins and Restart your computer.
3. Connect your MP3 to your USB port (note: better connect it first to a main hard wired USB port rather than Cardbus or Hub Port at least for the first time then u can connect it later to a hub) and thats it it should be recognised as an MTP device and then the name of your MP3 will show in the system tray as a portable device as well as the model number in your device manager.
Posted on Jul 12, 2008
Samsung player reset my files?
Like most Samsung electronics, the software is the pits, yet the hardware is generally quite good.
If the Samsung YP-K3 MP3 player continues to act erratically, a reboot, or reset, may help. Resetting this device allows you to reinitialize your player without losing your files or device settings.
The Reset hole is on the back of the device, toward the bottom. Press one end of a straightened paper clip into the Reset hole gently. Then allow the Samsung YP-K3 MP3 player to initialize.
You may want to upgrade and if you have, this may be why the files were reset.
YP K3 SUPPORT SAMSUNG
May 18, 2014 | Samsung YP-K3 MP3 Player
Tip
How to make computer identify your device
I had a problem with my YP-K3 when i lost the installation cd as my computer no longer identified the device when i plugged it in, to solve this (on windows XP) go to
1: control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your mp3 player is now recognised by the computer
hope it works
on Aug 11, 2008 | Samsung YP-K3 MP3 Player
The screen on my Samsung YP-K3 has become very dim and can hardly read it, can it be fixed
the drivers might need updating
NOTICE: The new Samsung Yp K3 device driver release resolves driver conflicts, improves your computer's stability and restores communication with all devices. The newly released device drivers are a high priority update recommended for all Samsung Yp K3 users
http://driversdownloadnow.com/download.aspx
hope this helps
Sep 25, 2012 | Samsung YP-K3 MP3 Player
Portable device is not recognised yp-k3
try to go to control panel then ADD NEW HARDWARE
that do the trick..
Jun 18, 2009 | Samsung YP-K3 MP3 Player
My computer don´t find out my yp-k3
The Portable services are stopped.
Open service list and activate.
Ciao
Apr 14, 2008 | Samsung YP-K3 MP3 Player
Cant access portable device in samsung media suite...its greyed out
Mar 29, 2008 | Samsung YP-K3 MP3 Player
My YP-K3 won't turn on
Do you have mediaplayer 10 or 11 installed?
Media player 11 is seriously screwed up software and will cause your computer not to recognise the player
You will need to remove ALL traces of media player 11 from you computer.
Jan 16, 2008 | Samsung YP-K3 MP3 Player
YP-KR
I couldn't get the icon for the portable device either. I solved the problem by going to the Control Panel; used Add Hardware; and followed the prompts. I used the original Samsung K3 CD. And it worked! Good luck
Dec 31, 2007 | Samsung YP-K3 MP3 Player
MTP Error
Dec 29, 2007 | Samsung YP-K3 MP3 Player
[I am looking in Device Manager as I speak] {model YP-K3}
Just right click and select update driver. then it will search online for a new driver.
Dec 25, 2007 | Computers & Internet
387 people viewed this question
 Grubhead
Grubhead
