Question about ASUS A7N8X-VM Motherboard
I know I have a driver issue but how can I solve it???? I just installed a new motherboard asus a7n8x vm 400 I installed windows XP Sp1 but when I got done I could not get a internet connection so I upgraded to Windows 7 and still got the same problem but with a new issue. The first Issue I was having was the computer would not log online. Under the Network and sharing center I?m getting an unidentified network message keeping my system from obtaining a valid IP address. For some reason it?s stuck on public network and will not let me change it to home. I tried all of the basic trouble shooting first by turning on network discovery then I checked my network cable; reset my modem and router, and rebooted my computer. After cycling everything and still no internet connection I tried to manual assign a IP address. next I tried to go online using a different computer to find a updated driver and transfer them via flash drive with no luck just the windows is using the best driver message. I tried installing Driver Detective put when I try to launch the program it shuts down because it don?t have a internet connection. The second problem I?m having is a unknown device in device manager. When I check the device properties under general and location it say that its on my PCI standard ISA bridge. I do have a vt6421a IDE/SATA raid card in stalled in 1 of the 3 slots but when I uninstalled the device and shut down the computer and physically removed the card and rebooted the same thing popped back up. Updating the driver didn?t work I tried to go to the manufactures websites to get all driver updates with no luck. So what do you recommend?
5 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: P5VD2-MX/P5V-VM DH ASUS Motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us
Go to ASUS downloadsite, the link above, in the box up to the left where it says "Input model To Search" put in P5VD2-MX, you will now recive 2 MoBos, chose the one you have, press enter, you will now be asked to chose OP, chose XP, all the drivers will now apear for you. Chose them you want, download them and instal them. I recomend you to instal them all since i belive that some of the drivers on your pc is old, thats why you getting that error message.
Good luck
Posted on Nov 25, 2008
  • 87 Answers
SOURCE: EVGA x58 SLI LE + VIA VT6421A RAID card Install without os?
There are many tools you can use to install RAID stuff. For example Hirens Boot CD http://www.hirensbootcd.net/details/10.2.html - the download may be broken but google it and you should find it quickly.
(http://www.hiren.info/downloads/freeware-tools/)
Also if you need to boot from a USB then try UNetbooin or  some of the tools mentioned on the site.
This should help to install RAID there are many tools on here. What kind of fussy os has to use SATA dvd drives anyway.
Nick
Posted on Mar 05, 2010
  • 133 Answers
SOURCE: I am having problem with
you might have to make sure the the bios says its on if thats not the case it might be faulty there for you might have to go and get a nic card which is like $20.00
Posted on Mar 24, 2011
SOURCE: IDE Ports not working on ASUS P5LD2-VM Mobo
This MOBO requires a driver in order to run the EIDE slot, so before it can be used use the CD-ROM and master HDD in the standard IDE slot to run Windows up then install the drivers then you should be able to rearrange things to have HDD's in the EIDE and other stuff in IDE.
http://uk.asus.com/Motherboards/Intel_Socket_775/P5LD2VM_DH/#download this is the download site, its the 2nd oiption in the RAID category
Posted on May 23, 2013
Have no sound after installing new asus a7n8x-vm/400 motherboard
follow that link to the asus support site.
http://support.asus.com/Download.aspx?SLanguage=en&m=A7N8X-VM/400&p=1&s=10
choose your operating system (windows xp, windows 7 for example) and download the driver needed.
Sep 18, 2011 | Computers & Internet
Need sm bus controller and ethernet driver for a7n8x-vm motherboard
Go to the Asus site:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Choose :
"Motherboard"
"Socket A (465)"
"A7N8X-VM"
in the dropdowns.
Enter your OS
Choose the "IDE" driver, that is actually an "all-in-one" chipset driver that should get you taken care of.
Feb 15, 2011 | ASUS A7N8X-VM Motherboard
I NEED DRIVERS FOR A7N8X-VM/400
All the drivers for your Asus A7N8X-VM/400 can be found on Asus Global link. Click the link below to open the site;
http://www.asus.com/product.aspx?P_ID=OYMrFEShYfp6m1dg
Have more problems post your question here.
Thank you for using Fixya!
Mike
Jun 24, 2009 | AMD ASUS A7N8X-VM/400 Motherboard
P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
Apr 19, 2008 | ASUS P5PE-VM Motherboard
SM Bus controller
Go to this Asus web site: http://support.asus.com/download/download.aspx?SLanguage=en-us
On the right side of the page fill in under, "Please Select the Product". Choose these.
Motherboard
SocketA(462)
A7N8X-VM/400
Click: SEARCH
Clcik: Utilities Find your operating system. Download.
Might be a good idea to download everything else since you do not seem to have your Mb CD.
If this helps you, please vote!
Jan 09, 2008 | AMD ASUS A7N8X-VM/400 nForce2 IGP...
ASUS A7N8X-VM Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
