Question about Sanyo DRW-1000 DVD Recorder/VCR
Shutting Off My DVD Recorder Turns On But Then Turns Back Off And Also Will Not Read The DVD's
  • chasa6210 Sep 27, 2008
    it won't play any dvds and turns off seconds after i turn it on
  • markDVD12 Dec 30, 2008
    I will transfer VHS information to the DVD. Upon completion, the power shuts off, but when I turn it back on, the DVD will not finalize.
My sanyo drw 1000 stops in the middle of running a movie ?
Posted on Dec 18, 2008
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The system or DVD recorder turns off itself
It could be because your unit is overheating. Shutting itself off is your player's way of protecting itself. Causes can be form anything to direct exposure to sunlight, Something heavy is on top of the player, to disk speed being to fast.
Mar 31, 2009 | GoVideo Go Video DVD/VCR Combo
My player says it cannot read disc
run the cleaner Dusc maybe the lense is dirty.
plz rate this post as good as u can so we can help others
Feb 08, 2009 | Lite On LVW-5005 DVD Recorder
Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Jan 04, 2009 | Zenith XBR716
Dvd recorder can't read disc it previously read
Take the Disc out and put it aside. You must clean the Laser Eye, and clean dust and other matter from inside your recorder. Clean Eye with rubbibg alcohol and q-tip. A regular CD/DVD cleaner disc will not work. After cleaning, reinsert your Disc and Finalize it.
Jan 02, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
TV Guide stopped supplying data
Gemstar (who owns the VCR+ system tied to your Panasonic) is shutting down the VCR + system - it is shutting down earlier in some areas.
-Tha Mp3 Doctor
Nov 24, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Can't Finalize Disk after recording
Your problem may be media related.This firmware upgrade has
helped me and others with similiar issues.
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders#
Be sure to read the instructions.If you don't know understand the
instructions,don't try it.You may make your recorder unusable.
http://www2.panasonic.com/static/Content/productsupport/dvd_firmware_instructions.pdf
Apr 03, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD-S31
have you ot it setting on something warm or hot like a subwoofer to surround sound or on top of a tv even if you had it there before and it worked they get older and cant take heat as well and they get dust built up in them alot of times one freezing or shutting off is getting to hot is it doing it right when you turn it on if so try unplugging it for a few hours then plug it back and try it
Feb 06, 2008 | Panasonic DMR-ES10 DVD Recorder
Reading and bad disk
You can press the eject button on the drive behind the front panel or connect the ribbon cable from the drive to a PC to eject it. More instructions are on my website here: www.drx9000repair.netfirms.com/
Mar 02, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Sanyo DRW-1000 DVD Recorder/VCR Logo
109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
