Sst4192 tv we can't get the remote to work with the tv (it works with the satellite)) we need it to go to line, input or aux for our daughter to play her game system
  • 2,326 Answers
Click here to go to the website that carries the remote control for your TV.
Posted on May 30, 2008
I have an older sharp tv from an older sibling and the cable works, but I'm trying to connect what I believe to be an older dvd player to it. The dvd player has the 3 color cords (red yellow and white)...
Those modes you gave are for what TYPE of signal is comming in to the Cable/Antenna connector.
You need to switch from that input device to the other input device, the RCA plugs. These are often displayed as Aux or perhaps Line etc. It would help if you had the remote from the tv and were able to choose Aux or Line, or if it has TV/Video button. But if not, try channel button on the tv itself and go down below Ch 1. If using the cable remote to control TV, it may have a TV/Video button too. Maybe.
Good luck
Jun 07, 2011 | Televison & Video
Have a vizio SV370XVT. 13 month old daughter was playing with the remote, and now none of the HDMI including directTV satellite and playstation are working. I can plug in computer to RGB and this works. ...
Hello there,
Push the input button on the remote control if you can not find it on the remote Control there should be a input button on the front of the TV .
Using the TV remote control or the DirectTv remote if programed for the TV.
i hope this information was helpful don't forget to rate
Jan 27, 2011 | Televison & Video
I bought the RCA RTD325W DVD home theater system. The speakers work with the dvd/radio tuner but cannot get them to work with tv. Also have Satellite tv, do I need to connect to something on that? Or is...
Your TV must have a set of Audio Out connections. Connect them to the Aux In on the back of the RTD325W. Then toggle the Line-In/Aux button on the remote until display reads Aux In. System should work.
Sep 08, 2010 | RCA Audio Players & Recorders
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to www.remotes.com to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
Jan 02, 2009 | RCA Universal Remote Control
Cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Nov 18, 2008 | Zenith B27B40Z 27" TV
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Connecting dvd player to zenith sy2551s system and doesn't work
Yes, You need to be on AUX ,you can get to that setting by pressing channel 01 then press the channels down button instead of going to channel zero it will start to cycle through your AUX's inputs on the back of the tv.Also, another way to do this is on the original remote there will be a SOURCE button or INPUT button that can also cycle your TV through the aux inputs.REMEMBER.Make sure your DVD player is turned on and hooked up or else the AUX screen will be black.Rate me when you fix it!GOOD LUCK
Nov 18, 2007 | Zenith SY2551S TV
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
