Question about Bosch Appliances 27 in. Wall Oven Electric Single
I have a Bosch oven, HBL 5045, and its display has been showing "F03 Err" the past few days instead of the time. It happened after our neighborhood temporarily lost power for a couple minutes. Any suggestions for how to remove the code? Thanks.
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
ginko
  • 19396 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Posted on May 24, 2008
  • 491 Answers
SOURCE: Door Hinges for Bosch oven HBL 545
CONTACT BOSCH FOR INFORMATION
Posted on Jul 18, 2009
  • 142 Answers
SOURCE: I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Posted on Sep 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Sep 27, 2009 | Ovens
HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Oct 14, 2008 | Bosch HBL 745 Stainless Steel Electric...
Oven cleaning
Error 41= Data cable shorted to ground//remove cable and reseat
Jan 01, 2008 | Bosch HBL 442 / HBL 446 Electric Single...
Bosch Appliances 27 in. Wall Oven Electric Single Logo
116 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
