Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
We replaced the belt after about 5 uses, and now every once in a while it smells like burning rubber, I checked to belt to make sure it was ok, and then last week it started smoking. Is there reported problems with this model?
  • 377 Answers
If the belt is hot or burning during use, it could be due to a beater brush, which the belt drives, being bound up in some manner. The beater brush is removed during belt changes and should be cleaned of all debris as best you can. At each end of the beater brush there is a plastic clip of sorts that holds it in the vacuum. Spray some WD40 between the bar and the plastic clips then rotate the clips to be sure they move freely. Reassemble with a new belt and put it to use.
If you find this solution to be of help to you I would appreciate a Thumbs UP rating. Paul
Posted on Oct 09, 2010
  • pwillitz Oct 10, 2010
    I am sorry my solution was of no help to you.
Vax troubleshooting
Burning smell from a vacuum usually comes from the belt....check
for any objects caught between the belt and the brush roll. Is the
surface selector at the correct setting?
Aug 16, 2014 | Vacuums
My Kenmore model 116 33300300C smells like burning when we use it. The bag has been replaced
If it is a burning rubber smell it may be the belt slipping. Make sure your brushes are clean and spin freely and then put the belt back on and see if that helps.
Apr 05, 2011 | Vacuums
When running it smells like something is burning
Hi
If it smells like burning rubber, then your belt is probably slipping due to having lost tension and needs to be replaced. If it's another smell, it could be the motor burning out, but that is often accompanied by smoke. There could also be something caught around the revolving brushes in the cleaning head. Lie the vacuum on it's side and make sure you can spin the brushbar freely by hand. Also check for any debris entangled in or obstructing the brushes. This would also cause the belt to slip resulting in a smell of burning rubber. It could also damage the motor so I suggest not using the vacuum until the source of the fault has been determined.
Instructions on replacing the belt can be found in your user manual. If you don't have one or need further instruction on how to do this, please post back for further assistance.
Regards,
BElectric.
Nov 25, 2010 | Eureka Capture Upright Vacuum Vacuum
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Loud noise and smell of rubber over heating
sounds like you have something stuck in the beater bar/roller and the belt is slipping. You're probably going to have to take it out and replace the belt. Also check for wads in the passages.
May 07, 2009 | Bissell 9200 Upright Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
157 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
