Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
D-7 is no longer working I need to open the body and find out the problem. I need to know how to open the body up?
    Brigadier General:
  • 11,967 Answers
Do you know anything about digital camera repair? Do you even know what's inside? Computer circuit boards....do you know what to look for?...How to test each circuit?...Do you really want to take the camera apart only to end up with an expensive paper weight?
Posted on Oct 09, 2010
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Gas pedal sticks/hard to push when first starting to drive. after that it is normal.
You need to clean the throttle body plate and bore area.You can get throttle body cleaner at your local parts stores.Just remove the air cleaner and the boot that goes to the throttle body and hold the throttle open.Take a rag and soak it with the cleaner and start cleaning the bore and the throttle plate til the tarish stuff is gone.You should be able to feel the plate not stick by moving it by hand to the open and close position.You can also spray it down with the cleaner before you wipe it with the cloth.You can use brake cleaner but then it takes longer to clean and you have to rub harder.Throttle body cleaner works the best.Hope this helps.Good luck.
Feb 26, 2011 | 1995 Pontiac Bonneville
I need to know where the thermostat is located in a 2000 pontiac grand am. 6 cyl. my heater no longer works and the car registers hot
I am not familar with your engine but follow your upper radiator hose to where it connects to the engine block. This is usually the thermostat housing. Another option is to buy a Haynes manual for your vehicle. cost about $20 at autozone
Feb 10, 2010 | 2000 Pontiac Grand Am GT
Need to know how to open the canister of my Electrolux Ambassador vacuum to replace the switch
If you switch still"clicks" you need a switch rocker, if it no longer clicks you will need a new switch button. You will get best results with the genuine button from an AERUS Electrolux repair shop
There are a set of body keys under the bumpers on this vac which slide forward to the front door with a set of pliers. They are locking one way so reinstall same direction . Examine the front hinge are before opening the vac. Once removed the panels will open like a **** shell from back to front. You will need to be careful realign all pieces in their tracks.
The switch is best accessed by removing only the bag cage. The housing will lif up without detaching wiring and the rocker and switch button will snap out as separate pieces. Test before reassembling and when done if the entire body does not assemble easily stop and check your alignment. It will click together like Lego pieces when you have it right.
Post back to advise how you make out
Nov 03, 2009 | Vacuums
The shower no longer cuts off completely leaving a constant drip from the shower head. I disassembled the valve body and discovered an unusual plastic split plate gate valve system inside. It appears to...
If the Shower or any tap keeps dripping then its from were the cut off of water comes from and if 2 taps then its either the seal and the seat needs recutting so the answer is to get the plumber out to recut the seat
If a mixer tap then you will have to get a replacement unit.....sorry
Sep 24, 2009 | Home
How does knowing the freezing point of water save lifes?
by lowering the body's temp at time of injury it prevents cell damage to major organs ( in the event of a heart attack the temp is very important due to the amount of cell damage that occurs in such a short amount of time) Persons have drown in 33 f water being submerged for 5 minutes or longer and are revived due to the body's temp drop there isn't much damage done to the brain because of the lesser amount of brain cell damage due to temp The colder the body the longer time is allowed for revival. Check info on cyrogenics for a better idea of the reson the temp is important Hope I didn't confuse you with this explaination
Dave
Sep 06, 2009 | Heating & Cooling
How can i open the body or case to repair of hp
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
314 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
