Question about Honda 2500 PSI Gas Pressure Washer
Starts but won't stay running, i clean carburator and still have same problem, unit has been used very little, still look new, Thanks,
Have you checked your oil? You need pump oil half way up in reservoir. Open plug on top of pump and check oil. Pump takes SAE 20 or 30
Next, open oil plug below engine and check your oil level. It should come up 1/2 way on dip stick. Engine takes 10W30. Don't turn washer on its side or upside down to drain oil or oil will run into carburetor.
Is the water turned on? Are you holding gun trigger open while starting? Pump needs water flow. DO NOT tie gun trigger open with wire and then start engine. That gun will flip around and shoot a hole in your leg.
If the engine starts, then you have gas, spark and compression
If engine won't stay running, the exhaust port might be clogged, or the carburetor is not letting in enough gas, or gas is not flowing to carburetor.
Check the screen over exhaust port > is it dirty or clogged? Clean with WD-40 or break it out with a screwdriver.
Remove gas filter below gas tank >>> it has a hex bolt >> loosen bolt >> the gas should come flowing out >> put it back if gas comes out
Next remove rubber gas line feeding gas to carburetor >> gas should flow out this line too >> if flows then put it back.
What about your air filter? Take it off. See if engine fires and runs without air filter. Air filter may be clogged.
While air filter is out, you can see open port to carburetor. Spray some WD-40 into carburetor. Fire up the engine. It should spark real healthy on the WD-40. Keep spraying WD-40 into carburetor to see if you can keep engine going. Don't forget to keep gun trigger open so water is flowing and pressure is not building in pump.
If engine keeps going with WD-40 but dies without it, then your carburetor is very suspect. You might need a new one.
If engine will not keep going with WD-40, then the spark is very suspect.
Change spark plug. Try again. If it doesn't fire up after that, you need to take it to the shop for repair.
Posted on Oct 09, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
Its the spark plug more than likely
Posted on Jul 13, 2013
Honda mower hrr 216 pda starts up fine, runs about 2 minutes and dies out. I remove the carburator, took it apart and cleaned it, cleaned out gas tank and replaced with new gas, new air filter and spark...
Hello Frank,
I would purchase a compression tester from your local parts store. Check compression when unit is cold, then run unit until it dies. When it dies, immediately check compression again. If reading are close to the same your problem is probably not internal. If you loose a lot of compression once unit is warm and dies, its probably internal and will need to be torn down.(compression should be at least 60 psi if not more) If readings are the same, I would purchase a spark tester and check before and after again to see if your loosing spark once unit is warm. If compression and spark are both good before and after, problem is most likely carburation. Hope this helps. Good luck and happy wrenching!
Sep 26, 2013 | Honda Garden
The lawnmower won't stay running long.
Clean your Fuel Filter and / or Carburator
Apr 13, 2013 | Garden
My blower sounds like the carburator or something is loose and it won't start easily and when it does it won't stay on or doesn't have good power
With the unit off, grab the carburetor and see if anything is moving. Sound like the cylinder may be loose. Before tightening cylinder screws check if the gasket is damage. If yes then change gasket.
Nov 12, 2012 | Craftsman 2-Cycle 27cc Handheld Blower/Vac...
Carburator leaks gas when cycle is started or running from what looks like vent hose?
Sounds to me like your float valve is obstructed by some debris. This is causing it to stay open and leak fuel. Better it leaks to your vent hose than it leaks in your engine and contaminates your oil.
You need a proper carb cleaning. Not some run in the gas tank sh*t. If the tank wasn't full when parked, chances are there is rust in the fuel system to get this out you need to disassemble the carburetor and thoroughly clean it.
Try not to ride the bike til you do this. It's a fire hazard.
Oct 08, 2012 | 2005 Honda VT 600 C Shadow
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Will not stay running
I cleaned the carburator on mine. That did the trick. Make sure you remove the bowl from underneath and clean the bolt. The bolt has holes in it that may be clogged. Clear it with a small wire. I then sprayed the carburator down with starting fluid. You may use carburator cleaner on the carburator, but I didn't I just used a brush.
Sep 27, 2009 | Oregon Scientific Gator Mulcher 3-N-1...
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Honda 2500 PSI Gas Pressure Washer Logo
5,660 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
