Question about LG Televison & Video
Hi, Am using the LG 22' tv as computer monitor what cable do i use to get the tv signal. Have comcast cable. Thank you, Michelle
  • 597 Answers
The comcast cable will do just fine.
As long as the port is available on the television, it is compatible.
Take care
Posted on Oct 09, 2010
  • wmlinke621 Oct 09, 2010
    I tried the comcast cable and tv still has no signal.
    Sergeant:
    Champion:
  • 431 Answers
Need to use vga cable
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
What do i need to attatch lg model# lh40 or 1080p to ny computer?
U have a VGA signal cable right there out of ur computer LCD monitor used that.Used a VGA signal cable connected to ur computer and than to ur tv VGA input than find the tv input like in 1,2,3,4 find the computer VGA signal that it.If u have new and a recent computers like a DUO CORE processor 2 or 3 it have a HDMI cable hub design in this computers.Just used a HDMI cable connected between the computer and tv to for work the best in HD.
May 09, 2011 | LG Televison & Video
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
Problem for LG 22" FLATRON Widescreen LCD Monitor LCD Monitor My monitor says analog power save and shuts off. Day before Yesterday I bought a new computer. I got the above mention problem on by...
The monitor is going itself to the Power Saver mode.It is not a problem of the monitor.This happens when there is no signal on the monitor.The monitor will display properly when there is an output signal on it.Please connect it to the computer and check that the output signals from the motherboard are proper.Also check both DVI (Digital Visual Interface) and VGA (Video Graphics Array)cables on the monitor.
Feb 23, 2010 | LG 22" FLATRON LCD Monitor
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
DVI connection
Did you try your monitor with another output (VGA)? If not, try it.
So, you have to check and make sure where the problem is (display card, monitor, or cable). Try with another cable or monitor. This way you will know where the problem is. If you don't have another monitor, try the monitor you have with build in VGA output on motherboard by taking the display card out.
Thank you,
Tan
Mar 04, 2008 | LG Flatron 295LM 22" LCD Monitor
Televison & Video Logo
108 people viewed this question
Computer Repairing
Computer Repairing
