Question about Cycling
Bicycle Avanti hurricane comp series - Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Please help me find a manual for a avanti atomic x-one thanku
You will not find such manuals because it uses standarized ways to build it up
A good site that explains diffent systems and parts is this site
sheldonbrown.com
Mar 14, 2015 | Avanti Cycling
Where can I get an exploded view of a shimano rear hub fitted to an STX RC
The hub could be anything. It's not determined by the shifter group.
If it IS a Shimano hub look around here...
http://techdocs.shimano.com/techdocs/blevel.jsp
Mar 16, 2011 | Avanti Ridge Rider
W84mykiss do you know that!
I will always wait for something as special as that !!!
c...
Jan 06, 2011 | Avanti Cycling
I have an AVANTI Blade 8 bicycle that has the shifter: Shimano Nexus Revo 8-Speed w/ Shimano Outer Casing. It has only done a maximum of 300 kilometres. Problem - The hub is not engaging. When i turn the...
This is a solution I strongly recommend you take into a bicycle shop. It will either be a problem they can fix (needs to be seen to properly diagnose) or a possible warranty issue which they would be the ones to take care of anyway.
The problem could be anything from an adjustment, which is far to complicated to explain with those hubs up to a broken part.
Thermostat for WC400ygb
personaly i would fit a universal one
Mar 13, 2009 | Avanti WC400YGB Wine Cooler
Comp was reformated
Don't worrly Fixya will help you in findding the setup disc very easily... To download the drivers, Please click on the below link or copy the URL and paste it in your web browser.. And Select DRIVERS, and select the operating system you are using and download the drivers..
http://www.brother-usa.com/downloads/Default.aspx
Thank you......
Oct 02, 2008 | Brother MFC 420CN All-In-One InkJet...
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Cycling Logo
209 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
