Question about Hitachi Video Cameras
Hitachi video camera VM E358E WONT EJECT THE TAPE need to get repaired looking for advice thanbkyou
5 Suggested Answers
SOURCE: Sharp Hi8 Video Camera VL H410
This camera needs to have the battery recharged in order to remove the tape.
Posted on Nov 20, 2008
SOURCE: Eject a tape from my Sharp View Cam
Try removing the battery and reinstall it if you haven't all ready tried this
Posted on Dec 26, 2008
SOURCE: can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Posted on Jan 23, 2009
  • 30 Answers
SOURCE: HDR-HC1 video camera won't close after you put the tape in. Hmm
MECHANIZAM fauly.repalace it by expert.
Posted on Jun 21, 2009
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
Nov 06, 2014 | Hitachi DZ-MV550 DVD Camcorder
How to download tapes from hitachi VM-E568LE 8mm to pc
Check out the newer Hitachi digital... (with analog conversion included)... Looked pretty promising.
Also the internet is rich with similar concerns ... and answers
Check out the links below
(Hitachi 1997 MPEG, MPEG-1 news release)
https://www.bing.com/videos/search?q=hitachi+vm-e568le+to+mpeg+conversion&qpvt=hitachi+vm-e568le+to+mpeg+conversion&FORM=VDRE
http://www.hitachi.com/New/cnews/E/1997/971119B.html
Jan 02, 2012 | Hitachi VME558LE 8mm Analog Camcorder
Tape wont eject, how should i get the tape out?
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 17, 2011 | Canon ZR200 Mini DV Digital Camcorder
When I inserted a new dv cassette into the camcorder to record - it chewed the tape then the "eject" message came up, I inserted a new tape and the eject message showed up again. I have also noted a whine...
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Oct 03, 2010 | Canon XM1 Mini DV Digital Camcorder
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
Apr 03, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Tape wont eject
The deck may have went. Try bringing it to a local camera shop to get it out for you.
Dec 31, 2008 | Sanyo VM-PS12 8mm Analog Camcorder
Video Cameras Logo
137 people viewed this question
Top Hitachi Video Cameras Experts
mega_mind
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
