Question about HP OfficeJet 6110 All-In-One InkJet Printer
"remove and check cartridge" error message
I have an HP Officejet 6110. It was working fine, then (after printting several documents), I attempted to print an Excel spreadsheet and the error message above showed up on my printer view screen.
I have replaced the ink cartridges (with genuine HP cartridges) and the message won't go away.
Help!
  • 1 more comment
  • Anonymous Jun 19, 2008
    Same problem. Printed one copy then I adjusted to make darker (doc to be copied in blue ink and not very dark)----now the "remove and check cartridge". Replaced the black cartridge but still the same msg. Also see msg that it has print que waiting.
  • Anonymous Jul 01, 2008
    I have a Hp Officejet 6110 All-in-One. Ever time i turn it on, it has an error in the message menu that reads remove and check cartridge. I've remove them and cleaned them both and the problem still continue, along with a humming noise.
  • Anonymous Aug 01, 2008
    remove and check cartridge error
Http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
Posted on Jun 24, 2008
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant print and im getting an error message
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Sep 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 won't accept new cartridges.
Check these HP FAQs for your printer:
Also see, at the end of each one, the links to related printing problems.
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
323 people viewed this question
Seeker5211
Seeker5211
