Question about Husqvarna Sewing Machines
I have a Husky 2221 and I've lost the manual. Having problems threading needle & bobbin. Are you able to help?
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
My Singer 648 is having a problem with the bobbin thread getting caught up in the bobbin case and jamming the thread inside the case breaking the thread. Is there a solution to this problem? Thanks
try changing the needle
make sure the top thread has not come off the thread take up lever
try another bobbin
make sure the bobbin is turned the right way in the bobbin case
try rethread the machine top and bobbin
clean under needle plate and in the bobbin area for lint or threads
Jan 06, 2013 | Sewing Machines
Bobbin pops out and needle thread and bobbin thread bird nest
here's my suggestions
change the needle-make sure the needle is inserted correctly
into the needle holder & also turned the right way
make sure when sewing on the machine that the top thread does
check the top thread tension it may be too tight,, usually 4 is good
or if the machine has automatic tension set it there
make sure it's the right needle for the machine & make sure it's the
right needle for the fabric & thread.
some thread is knotty ,,, make sure the thread is good quality
Sep 10, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
rethread the machine top & bobbin
make sure the bobbin is not over wound
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
My needle wont sew on my husky star 207?
change the needle--make sure it's the right needle for the fabric
being sewed
rethread the machine top using every thread guide
check to make sure the bobbin is not over wound, make sure the
bobbin is not warped, & that the bobbin is inserted correctly into the
machine
it's also possible that the machine is out of time
Jul 14, 2012 | Husqvarna Huskystar 207 Sewing Machine
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
After taking only a few stitches, the bobbin thread becomes tangled and knotted. I've cleaned and oiled the shuttle and cover and adjusted the tension, but it still happens. Advice?
have you tryed changing the needle?
have you tryed changing the thread on top & bobbin area?
some thread & needle are not compatable--here's a tip I learned from a sewing expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
hope this helps
Oct 12, 2010 | Husqvarna Husky 145
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
114 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
