Question about Frigidaire GSTF1670A Front Load Washer
Frigidaire front load washer were are the filters
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 378 Answers
SOURCE: Frigidaire front load washer wont high spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Apr 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
  • 11 Answers
SOURCE: Frigidaire front load, ERR LOC, washer won't run
the washer is not broken, that means the control panel is locked,(child safty feature), press the two buttons with the pad lock symbol in for 3 to 5 seconds and that will unlock it!!
Posted on Nov 15, 2009
Where is the drain pump filter on the Frigidaire front load washer?
You will need to remove the back of the machine. Then, look on the bottom of the tub, you will see a drain hose that you need to remove from the tub and there is a filter inside of it.
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Oct 01, 2010 | Frigidaire Affinity ATF6000F Front Load...
ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Lint filter/can't find
THERE SHOULD BE A TRAP DOOR EITHER RIGHT INSIDE THE FRONT DOOR OR ON THE TOP OF THE UNIT MORE LIKELY RIGHT INSIDE THE FRONT DOOR
May 29, 2009 | Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 41742042100 front load washer
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Jan 02, 2008 | LG WM2688H Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GSTF1670A Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
