Question about BellSouth 1010PR (14 Channels) 2-Way Radio
How do i get my bellsouth 1010 walkie talkie to scan? it only says busy.i can send out,but will not recieve
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
You have your interference code eliminator set differently on the two radios. Here is a link to the T5 user guide (sorry I didn't have a link to the T3, but they should be very similar): http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Posted on Feb 28, 2010
  • 4 Answers
SOURCE: BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Posted on Apr 30, 2010
How can I get operating procedure
First charge batterys all night long.
then look if there is ok,the batterys
Then turn it on and try transmitting putting both at the same channel band.Turn volume key counter clockwise at half
Jul 18, 2014 | BellSouth Bell South Call 1010 Walkie...
I need a manual for this
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
May 21, 2014 | BellSouth Auto multi-channels 2-way radio...
Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Feb 28, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Feb 27, 2010 | Motorola Radio Communications
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Aug 27, 2009 | BellSouth Radio Communications
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Bellsouth 2231 Walkie Talkies and No Manual
I think this is the document you're looking for:
link <http://www.scribd.com/doc/3783989/>
Sep 27, 2007 | BellSouth 1061 (14 Channels) 2-Way Radio
BellSouth 1010PR (14 Channels) 2-Way Radio Logo
214 people viewed this question
Top BellSouth Radio Communications Experts
ka4iup
ka4iup
BJ Russell
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
