Question about Sony DCR-HC26 Mini DV Digital Camcorder
Can't see the image it turns on but some how it gives you a dark screen
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
Dark picture good sound, backgroung image on screem
There may be different reasons for that.
Here's an example:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Find out the model / chassis and give a better description for the problem in order to get better help.
Aug 21, 2013 | Sanyo 42 in. LCD TV
Olympus Fe-4000 screen is completely black no image available
Stephan is exactly right. I have a FE-4000 and the LCD screen is most likely dead. As Stephan said, the screen should be replaced by a professional.
Cheers to all
dmklunk122
Dec 16, 2009 | Olympus FE-4000 Digital Camera
My Compaq Presario v2000 will turn on but the screen is just black what do I need to do to fix it?
Can you see any image on the screen in a dark room, using a flashlight sometimes helps. An image will be most visible right after you turn the laptop on, when the logo appears. If you can see the image but it is dark you need a new probably backlight inverter which is a relatively easy and cheap repair - I usually charge less than $50. JC Hunter
Nov 13, 2009 | HP Compaq Presario V2000 Notebook
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dark Screen
The back light is bad in your monitor. This is the light source that gives light to the image on your screen so that you can see it. This is a common thing to go wrong with a laptop. You can take it to someone to be repaired or if you are handy you can buy the part and replace it yourself.
Jan 18, 2009 | HP Compaq Presario 2200 Notebook
Mine will turn on, but cannot take pictures
this a CCD failure !! but u are LUCKY enuff
u can get it repaired free of charge it is a manufac fault many face it
see ur self
http://www.imaging-resource.com/badccds.html
see the link dont worry if ur model is not incl in the letter they willdo it free of charge just give them a call and pls rate me FIXYA forhelp
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
for asia
http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Dec 23, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
NEc plasmasync 42mp2 - dark screen and in the top few pixels show the image
It's either the Y-main or logic board but you would need to do some extensive testing to know for certain which one... It's not the screen..
I would strongly recommend you take it into a shop and have a Tech test it and give you an estimate..
Bill
Nov 17, 2007 | NEC PlasmaSync 42MP2 42 in. Television
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Sony DCR-HC26 Mini DV Digital Camcorder Logo
22 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
