Question about Panasonic PT-61LCX70 61" HDTV
THE LAMP IS BROKEN - Panasonic PT-61LCX70 61" HDTV
  • 597 Answers
First of all, unplug the TV from the wall outlet.
You have a few thousand volts going through your ballast, be very careful!
It's also a good idea to let the TV cool down for a good 15-20 minutes as the bulb itself can get extremely hot.
Locate the lamp enclosure door; it's usually at the back of your television.
There is a screws on the bottom of the lamp door, remove them using a Philips screw driver.
Take the lamp door out by dismounting it from the bottom.
inside you'll find the lamp enclosure,
On the side of the plastic enclosure there is a screw that secures the enclosure, uninstall it with a Philips screwdriver.
Pull it out the old enclosure from your TV and slide in the new one.
Reinstall the screw on the lamp enclosure.
Place the lamp door back in its place.
Secure it tightly with the screws on the bottom of the door.
Take care and good luck
Posted on Oct 09, 2010
The electronic circuit broken, lamp doesn't work
listed under air purifier,send to manufacturer
Jul 01, 2015 | Air Purifiers
What can i do for error code 5300 on kyocera 9130 printer
Broken cleaning lamp wire While the cleaning lamp is on, the broken cleaning lamp wire detection signal is detected for 2 s continuously.
Id look at replacing the drum unit
Aug 13, 2014 | Kyocera FS-9130DN Laser Printer
Kyocera fs9130dn
Jul 24, 2014 | Kyocera Office Equipment & Supplies
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I'm getting a flashing light for lamp cover and suddenly can't get my projector to show the show? tony
the swith that the lamp cover engages is not functioning. either the tab on the lamp door is broken off, the actuator on the switch is off, or the switch itself is broken. the lamp won't light if it thinks the door is open.
Nov 04, 2009 | Sony VPL-CX85 3000 Slide Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Panasonic PT-61LCX70 61" HDTV Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
