Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens auto focus sometimes does not work
I dont know hao to clean the contacts?
  • Iron_Biker May 30, 2008
    i don't know how to clean it, i already tried pencil eraser.
  • Iron_Biker Jun 01, 2008
    I cleaned the contacts as recommended but the problem continues, this is the only lens I have with this problem and already try it with my new Canon 40D and it behaves the same way. Should I send it to Canon?
  • 22 Answers
Pencil erasers can remove and clean, but rubber is an insulator. Don't go crazy with this, but just a bit of 91% rubbing alcohol on the end of a Q-tip applied gently to contacts will remove oxidation and improve electrical contact. Do the lenses first (I assume more than one). If this still doesn't help, then the problem is with the camera. This is a service issue (repairman). If you only have one lens, try it on another camera. Since you say "sometimes" I think cleaning will do the trick.
Posted on May 30, 2008
  • fred hutchings Jun 04, 2008
    If you can, take the camera and lens to a camera store and ask to put another lens on the body. If the problem persists, then the camera is at fault. If you can put the lens on another camera body, then the lens. Based on your response, I would have to bet on the lens having a problem. Cannot imagine a dealer not helping you out here. You spent a lot of money, and if there is a problem, let the dealer return the lens for you. The extra charge can't be that much, and checking it out through a sales outlet sounds safe.
Auto focus dosen't work
You are sure on both, the camera and the lens, AF is selected?
If you did and the lens does not work, please try anther lens, to find out, if it is a malfunction of the lens or of the camera.
You also could check if all contacts on the lens and in the camera are clean and not corroded. If the are not clean and shining, please use a dry cloth to carefully rub the contacts clean. Be careful not to bend any contact in that process. please be careful not to leave any dust n the camera or lens. Use the lens and camera caps when you are not cleaning one of them.
Dec 18, 2013 | Nikon D40X Digital SLR Camera Digital...
The 18/55 mm auto focus lens stopped working
First, make sure that both the camera and lens are set to auto-focus. The problem is possibly as simple as dirty contacts between the lens and the camera's lens mount. Depress and hold the lens release button while you fully rotate the lens back and forth about ten times. The friction between the contacts on the lens and the contacts on the lens mount will clean the contacts.
Jan 12, 2012 | Nikon D40x Digital Camera
I have the canon 50D and the 24-105mm L lens. Yesterday i took some images, and it worked fine. Today the auto focus is not working. When i press the button half way, nothing happens. If while i'm pressing...
This to me is a connection problem and may only require moving the AF-MF button back and forth a few times or removing the lens and cleaning the contacts between the lens and camera body.
Generally the "L" series lenses are pretty resilient in construction of offer the user few problems.
The lens contacts can be cleaned with a soft red rubber pencil eraser where you lightly polish the contact area of the gold contacts. Clean away any rubber dust with a lens cloth not a tissue, be extra careful not to get dust into the camera body cavity. reassemble the lens and try the camera lens operation
Diagram
This should clean up the problem
Jan 20, 2011 | Canon 24-105mm f/4L IS USM EF Lens
I have a Nikon D70 (with a 18-55mm lens) and have always used it in Auto mode. It suddenly stopped working in auto mode...won't take the picture at all. Did I break the lens??? If I tip the camera back...
Hi tina549, do any of your other lens auto focus? If so then it may be this lens. If they do not then look on the right side of the lens mount (with camera facing you) there is the AF and M switch. Something to try is clean the electrical contacts on both the D70 and the lens. When I had a D70s the auto focus was giving me fits, worked sometimes then it did not so I traded it for the D80. The 18-55 lens is a nice lens however, it is not the most robust of lens.
Jun 11, 2010 | Nikon D80 Digital Camera with 18-135mm...
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My Auto Focus lens doesn't auto focus.
try powering cam without lens then put on. try different lens. if not internal menu should have a lens cleaning option
Jun 03, 2009 | Nikon D80 Digital Camera with 18-135mm...
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Trouble auto focusing
If it's any consolation, I have the same setup and the same problem. I'm now at the point where I'm probably going to have to return the lens as faulty, but there are a few things it could be on yours which you might want to check.
Have you got the D200 set to auto-focus? The selector (on the front of the camera, on the lower left) should be in the S position (as opposed to C or M).
Have you got the lens set to auto-focus? It should be in the M/A position, rather than M.
Have you tried cleaning the contacts? Pop the lens off and give the contacts a clean with the appropriate equipment. Dust on the contacts could be causing a problem.
Failing that, have you tried turning the camera on and off a few times?
I've obviously tried all the above on mine, and now suspect I've got a faulty lens that needs fixing ... which really sucks! Good luck with it, let me know if you get it working.
Dan
Jan 20, 2008 | Nikon D200 Digital Camera with 18-200mm...
Lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
