Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have intuitive eco washing machine and it has come with code 66 call service wot is code 66
  • toemotu Oct 09, 2010
    thank you the solution is most helpfull
  • 10,515 Answers
This is a bad error. This means that (01000001) Pressure Transducer Error (Ptx frequency >90kHz)
The motor controller has received signals from the water level sensor (Ptx) above normal frequency values.
You need to replace the motor control module to get this fixed.
Note - You could try to reset this code by disconnecting the power supply for few minutes, say 15 minutes. If problem persists, replacement of motor control module is the only solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
Error code 66
66. (01000010) - Pressure Transducer Out of Range Error
The Motor Controller has received signals from the Pressure Transducer outside normal values.
Primary Source - Motor Controller
Action - Replace Motor Controller
Feb 11, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
The model; intuitive eco I need service fault code
RPS fault. this part can easily be replaced. the rotor part of the motor needs to be removed (5/8 socket) then you will see the RPS on the side of the stator. loosen the 4 bolts (3/8), pop it off, replace.
Aug 14, 2013 | Fisher and Paykel Washing Machines
Needs service code 66
The pressure sensor is faulty and needs a new/good secondhand one
You can get one from an old dead board,
But it needs to be calibrated to that board.
To calibrate the new one set machine to fill to low water level,
The plastic hex with red on it needs to be turned up to raise & down to lower the water level.1/8inch of a turn will adjust water by 15 to 20mm.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
Primary Source: Motor Control module
Action: Replace Motor Control module
Jun 17, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco fisher & paykel washing machine
this is a pretty clear cut fault (66). It is a problem with the pressure transducer (water level). The only cure is to replace the motor controller (which is the lower of the 2 modules in the console)
Oct 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
256 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
