I cant watch a movie with the attached dvd on my dx-ldvd19
  • 597 Answers
If you cannot watch a movie with the attached dvd on your dx-ldvd1, you have to first check your connection if it is properly done, ensure the video out prongs from are properly connected to the dvd and the video in is properly plugged in the vidoe in of the television. Also do same for the audio cords too.
If you have assessed it to see that they are properly plugged, then you check if you have the television on the AV channel or mode to be able to watch movies on your television.
If you have checked all these and see that they are all properly connected, then it is obvious that the problem is from the prongs, probably they are bad and need replacement.
Take care and good luck
Posted on Oct 09, 2010
What size screws attach the swivel base to the Dynex LCD-TV Model DX LDVD19 10-A? There are screw holes. Many thanks!!!
take it to a repair shop and have them check the hole size they may actually have screws just for that reason
Nov 05, 2017 | Dynex Televison & Video
Wont read dvd
Either the reader on the drive is bad, or the disc itself is damaged so as to cause the computer to read it as having no data
Jan 19, 2014 | Dynex DX-LDVD19-10A LCD TV
Dvd is stuck in the player ... DX-32LD150A11..
There should be a small, pin sized hole on the face of the DVD player. It may be hard to see, but it should be there and close to the eject button. This hole is the manual eject override. Turn the power to the player off, and slowly slide a paper clip or pin into the hole. The disk should start to come out. Once you have enough to grab, grab it and pull it all the way out.
If this does not work, the disk is jammed because it jumped off track. Something like this may require disassembly for removal and would most likely indicate the player is damaged.
May 09, 2011 | Dynex DX-LDVD19-10A LCD TV
Watching a movies screen black out but there is still sound
Can you see the menu on the display? If so, then your DVD is not compatible with the system (ex. system NTSC and DVD is PAL or SECAM). If you don't see anything at all then the display is broken (inverter is down or some diode responsable with the power circuit of diplay).
Jan 27, 2011 | Dynex DX-PDVD7 Portable DVD Player
Can I attach a speaker to the model DYNEX 19" DX LDVD19-1? The built in speaker is hard to understand.
Yes surely you can attach any home theater of your choice by using audio output socket provided in the LCD.
Jan 22, 2011 | Dynex Televison & Video
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
My asus dvd burner will burn the movis but i cant watch it in my dvd player. but other burnt movies i can
use from dvd burner to putting some special files that need for dvd players.only write your movies on movie mode!
Jun 24, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Cant burn pictures to cd
There is nothing like burner wont work.
If you are using Nero then select text in the column displayed in the side pane and attach the photos, movies and etc....it will burn.
Im sure.....
Jun 03, 2009 | Acer Aspire™ T180 PC Desktop
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
