Question about Mitsubishi WT-42311 42" Rear Projection Television
My WT-42311 will not stay on. When I push the power button, the green lignt stays on for 2 second, blinks twice & shuts off.
  • 10,515 Answers
The code 2-2 does indicates a short protect fault, which is usually caused by a failure in the convergence section. This is a very common repair in these sets. The typical repair involves replacing the convergence ICs (integrated circuits), and testing/replacing two small pico fuses.
The replacement ICs for your set are part number: STKxxx-xxx and are available from www.encompassparts.com for $19.95 each (needs two). You will also need at least one (likely two) 5 Amp pico fuses. If you wish to repair this yourself, the ICs are located on the large heat sink on the center (Power) PC board. The fuses are also on this board, near the center, location numbers: FXAXX and FXAXX. You would need soldering equipment and very good soldering skills to replace these parts.
An image of the same would be ( the below one is a generic picture ) :-
If you were to call a local shop to repair this, the labor to replace these is roughly $250-275 (in my area) if the TV were brought in to the shop. Please add a trip charge if repaired in the home.
The fuses must be tested with a multimeter to see if they are bad. They are only $2.50 each, so most people without a meter just change them both. If the repair has any problems, like a solder bridge, you may need a meter to check them after that. A good magnifying glass helps prevent solder bridges (for me, anyway).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
42 mitsubishi how do you know power supply is faulty?
have you tried accessing the self diagnosis feature to see how manytimes the power indicator blinks after accessing ? If so let me know the blink code and I will assist you with the issue.
Oct 03, 2012 | Mitsubishi WT-42311 42" Rear Projection...
My t.v. dont stay on
First do a hard reset. Merely unplug the power cord for 4 hours, then restart it. This will correct it if the cause is corrupted soft codes.
If not, the protection circuit has captured the power management and you must have it looked at by a service tech.
Let me know if there is more.
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WT-42311 42" Rear Projection...
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 15, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Tv won't stay on
2 of 3 circuit boards in your Mits can give your symptom...
1)Center power supply board = open fuse & bad IC's
2)HV scan board defective.....
A qualified Mits tech with parts in stock can fix it.......T.
Dec 13, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
