Question about Air Tools & Compressors
Where can I get rebuild/overhaul kits for DeWalt and Porter Cable 5/8"-2" finish nailers?
    President:
  • 1,388 Answers
Kits and parts are sold at your nearest dewalt service center or if you like to order parts on-line check out www.toolpartsdirect.com . They have good prices and fast delivery service for parts in stock. Good luck
Posted on Oct 10, 2010
My Porter Cable fn250c finish nailer does nothing when I press the trigger.
Could be lack of lubricant or safety foot not pushing trigger valve pin all the way in. Easy to check. Remove nails and remove trigger to expose the trigger valve firing pin. Connect air and with very quick action depress the firing pin all the way in with finger. If gun fires adjust safety so it pushes on trigger pin completely. If no fire, remove head and head valve and apply plenty of white grease or silicone paste to orings and reassemble for retest. Good luck
Jan 09, 2017 | Dewalt Air Tools & Compressors
How do I overhaul porter cable PN 100
Look on Google to see if anyone has posted instructions or a Youtube video.
Oct 04, 2014 | Porter Cable Tools & Hardware - Others
Dewalt 51256 finish nailer, 16 gauge. Shoots two brads at same time. Using Porter 16 gauge brads. Any suggestions
Replace the trigger valve part # 647956-00 to solve this problem. If you have access to very small orings (2mm x 1.5mm), try replacing the two orings on the trigger valve stem. Dewalt uses vinyl orings on the trigger stem and they fail causing malfunction. Easy fix however and not expensive . Good luck
Feb 24, 2014 | Dewalt D51256K 16 gauge finish nailer kit
Describe your 2 - 1/2"
Not sure what you question is however Porter Cable and Bostitch are now part of Dewalt. Parts and owners manuals as well as other documents are available at the web address below.
http://servicenet.dewalt.com/
Aug 24, 2011 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Need owners manual for Porter Cable FN250C 16 Ga. nailer
Here's a link for PDF file download of your manual.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
Apr 15, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
My gun is leaking air ... a have 2 finish nailers and are leaking air , please can u tell me where can send those to fix?? i'm in north south carolina my sip code is 29536
The closest loction to you is in Charlotte:
DELTA | PORTER-CABLE/DEWALT FACTORY SERVICE #042
3557-B WILKINSON BOULEVARD
CHARLOTTE, NC 28208
US
704-392-0245
Oct 01, 2009 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
BN125A Nailer will not fire even after rebuild kit
low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
May 27, 2009 | Porter Cable Cable Brad Nailer and...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Air Tools & Compressors Logo
70 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
