Question about LG LRG30357ST (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Range
My LG gas range LGR30357ST Has no response when touching the touch pad controls, Therefore I cannot operate the oven. What is the solution ? Thank you
SOURCE: kg800 lg choclate phone touch pad isnt working
How do I chk the keys?
Posted on Feb 25, 2008
  • 210 Answers
SOURCE: LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
Posted on Jun 01, 2008
SOURCE: lg lre30451st right front/right rear burners won't come on
I tried this on the advice of another post. It worked for me and now all of my burners are working again!
Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start"
Posted on Jul 30, 2009
SOURCE: LG Secret touch screen, can not use left upper,
I have the same problem sometimes, when it happen I press the touch media key in the middle right side of the phone, and enter to the pictures aplication and exit touching the screen, this appear to recalibrate the touch pad most of the times.
Posted on Aug 22, 2009
erickson_kj
  • 10 Answers
SOURCE: lg dare Touch accuracy is not within the range
Go to the main menu, settings and tools; touch settings : and then select calibration and touch the six targets to calibrate touch accuracy
Posted on Sep 06, 2009
Cannot set oven temp - LOC is being displayed
This is a symptom of the control panel lock. It prevents the oven from being turned on when you clean the touch pad. Press and hold 9 and 0 at the same time for at least 3 seconds (until the control beeps twice). The message should disappear and the panel should begin to work.
The manual is available at the LG site: http://www.lg.com/us/appliances/ranges/LG-gas-range-LRG30855ST.jsp . Click on the Support tab and look on the right hand side of the page.
I hope this helps.
Feb 13, 2011 | LG LRG30855ST Stainless Steel Gas Range
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
My magic chef gas oven showed the F1 code. I tried to self clean the oven and some wires under the cooktop started to melt and smoke.
Hi nelson1999,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | Magic Chef 31000 Gas Kitchen Range
It giving me a code -f-1 what does that mean.
i have found the code that you are looking for and hope that it helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank you for writing to fix ya.
Best Regards Richard
Feb 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Two of the touch pads for the burners are not working. 1. You touch the pad and two lines come up. When you touch high or low it does not change. 2. Touch the pad and the same two lines come up and the...
You have a bad membrane touch control. Check your owners manual for warranty on the electronic control. If it is out of warranty you need to call an authorized LG service dealer for a quality repair.
Jan 23, 2010 | LG LRE30755 Electric Kitchen Range
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
LG LRG30357ST (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Range Logo
74 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
