Question about Vacuums
Is white negative or positive? I s dark green negative or positive?Which one lines up with black? Which one lines up red?This is for a wall light.
    President:
  • Vacuums Master
  • 1,932 Answers
please watch the video from below website and this shows the colors of wire and for which it has been used.This video you can understand better than explaining in words
http://video.about.com/electrical/Identify-Wire-Color-Coding.htm
Thank you
Posted on Oct 09, 2010
Which wire is the power wire on the jlt pump
post a picture of the wiring but hot is generally black neutral is generally white ground is always green sometimes they use red blue dark yelloow purple as hot so it is hard to say which color the unit uses there are only about 3 wires maybe a 4th if it has a seprate switch for the pump but the picture of the circut would answer my questions
Jul 12, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
Purchased vanity light galaxy while instructins are clear for black and white wires it also has a green and yellow wire is this just a ground wire
The green and yellow wire is indeed the earth wire, black is the live wire and the white is the neutral for US connection. Please rate this solution.
May 22, 2011 | Galaxy Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I am trying to install a ge digital timer (model 15086) for a porch light. I have one black wire and one white wire coming from the wall. The timer has a white, black, red and green wire. How do I procede?
I am commenting on things are here in the u/k not u/s which is not the same but i hope this is of some help.......From the wall black and white ,this is a switch wire which is on or off, i would link this to white to white , black to black or black to red with the rest left unconnected,,,,,Check to see if you have fitting instructions indicating what wire goes where....Good luck
Feb 19, 2011 | GE Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
Have a great day.
Jim
Dec 30, 2010 | Vacuums
Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
1935 KIRBY Model R*
19?? KIRBY Model 2R
19?? KIRBY Model 3R
19?? KIRBY Model 4R
19?? KIRBY Model C
1939 KIRBY Model 2C
19?? KIRBY Model 3C
19?? KIRBY Model 4C
Model 505 - 1945
Model 508 - 1948
Model 509 - 1949
Model 510 - 1950
Model 511 - 1951
Model 512 - 1952
Model 513 - 1953
Model 514 - 1954
Model 515 - 1955
Model 516 - 1956
Model 517 - 1957
Model 518 - 1958
Model 519 – 1959
Model 560 - 1960
Model 561 - 1961
Model 562 - 1962
1963/64 Sanitronic VII (Sirocco)
1965-67 Dual Sanitronic 50 (Sirocco)
1967-70 Dual Sanitronic 80 (Avocado green)
1970-73 Classic 1CR (Medium brown, gold bag)
1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
1976-79 Classic III 2CB (Candy-apple red, plaid bag)
1979-81 Tradition (Dark blue; intro of paper bag)
1981-84 Heritage (Gray/orange)
1984-89 Heritage II Legend (Charcoal/gray/red)
1989-90 Legend II (Dark rose-pink)
1990-93 Generation 3 (Alabaster)
1993-96 Generation 4 (Medium gray)
1996-99 Generation 5 (Maroon)
1999-01 Generation 6 (Black/Yellow)
2002-05 Kirby Ultimate G
2005-06 Kirby Ultimate G Diamond
http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I bought Roomba 560 robot vacuum cleaner about 3 weeks ago and it has been cleaned without problem all kind of positions of floors (also carpets) Last friday I anyway mountained nearby of outcoming door...
Roomba won't clean black carpet because it interprets it as a cliff. The sensors under the bumper tell the Roomba that it's about to fall down the stairs and it backs away. Unfortunately, because they're a safety feature, they can't be shut off.
Aug 18, 2009 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
