Question about LG Washing Machines
When pulling out heavy load pulled out front rubber from front of machine noticed steel ring with spring very rusty so purchased new one. problem is I dont know where this steel ring goes and cannot operate machine without it. I have a LG 7.5kg model WD/1049 c front loading machine.Please help before I blow a fuse!
  • 1 more comment
  • malpambanora Oct 09, 2010
    Hi
    Thank you for your help, are you able to provide a diagram or more information as I am still having trouble aligning the rubber to the machine. Thank you Kindly
    Can you please provide a diagram if possible or as much information as you can. thank you kindly
  • malpambanora Oct 10, 2010
    yes, very helpful
  • LG Master
  • 19,396 Answers
Hi.
I uploaded the full service manual at the link below. The schematic views are in the last pages of the manual.
Try first:Click here to start download..
If that does not work, proceed from: WD-1049C Service Manual
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 09, 2010
    President:
  • 1,554 Answers
The spring and hoop assembly secures the door gasket over the outer lip of the door opening. It goes around the door gasket with the spring positioned at the bottom of the door opening. Start putting the hoop at the top of the door opening then the spring at the bottom while stretching it.
  • Jahn27
    Jahn27 Oct 09, 2010
    Put the door gasket untwisted over the outer lip of the door opening then secure it with the wire hoop and spring assembly.
The machine gets out of balance during spin. Heavy load ,light load doesn't make any difference. When I stop the machine and rearrange clothes and then press start the water comes on and it goes thru...
To verify my suspicion, it will be necessary to pull the machine out from the wall and remove the lower panel which is normally only a half-dozen screws.
With the AC plug pulled and a good light, check the tub suspension which will be located at or near each corner and may be either sturdy springs or heavy rubber rings. They must all be attached to hold the tub centered. One of these has failed or at least come loose from its anchor.
Jul 06, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
The rubber ring inside the washing machine came out and a metal ring was under it, i dont know how to fix it?
that rubber is called the bellow. snap the bellow back to the machine. place plastic ring over it into the grove and work it all the way around. that metal ring should have a spring on it. use a needle nose pliers and pull the spring so it stretches, metal ring should snap right in place.
Feb 05, 2011 | Whirlpool WFW9200S Front Load Washer
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
I need to replace the door lack how do i do it??
the front boot can be pulled off from the front to get to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
373 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
