Question about HP Office Equipment & Supplies
My plotter does not recognize always that a printer cartridge is seated and will print without cyan
  • TSagriff May 30, 2008
    I have a designjet 755CM HP plotter. I will try cleaning the contacts....That does sound like it could work....I did wipe them gently with a lint free cloth slightly damp....which didnt work. There is no error message given - It will print without the colour(s) in question...Just wrong colours because blue is not mixed in.....ie pink for blue - yellow for green. And it seems somewhat random..The blue doesnt work but when I reseat the blue and restart maybe the yellow doesnt work now either......irritating.
    Thanks I will try cleaning the contacts.
    Tara
  • 43 Answers
A model # would help. HP makes cleaning kits for the majority of DesignJet plotters that includes a tool to clean the contacts in the carriage that holds the printheads. Other than that, you could try a chamois swab (I think you can still get them at Radio Shack) dipped in 91% isopropyl alcohol (shake of the excess) and try cleaning the contacts that the printhead comes in contact with. Oxidation and/or ink can cause a bad connection that gives you the no printhead error. Reply with the DJ model # & I will be happy to get you the cleaning kit part #. Here is link for to the cleaning kit for the DJ 330, 350C, 430, 450, 455CA and 700.
http://www.hp-bazaar.com/cartridge.php?product=HP-C6247A&type=HEW Hope that helps you...
Posted on May 30, 2008
What is the solution to 59.51 error on HP 500 color LaserJet printer.
59 error refers to a Printer motor Error.
59.51 however should not appear on screen.
59.5 is a "Print Cartriddge motor Startup error". The last character should be a letter for which Toner (ie. C, M, Y or K). However I would suggest that the 1 would be the Black motor (seeing as it is the top one). Considering you have replaced the DC controller recently I would say the most likely cause is you have either misconnected or not connected a cable. recheck all your DC controller connections and pay particular attention to connectors J1013 (Cyan Motor), J1031 (Magenta Motor), J1032 (Yellow Motor) and J1033 (Black Motor).
OR
1. Check the cyan cartridge for broken pieces and make sure the drum spins. if so, replace the cyan cartridge
2. Check that connections on the cyan print-cartridge drive motor and on the driver PCA are seated correctly.
3. Replace the cyan print-cartridge drive motor.
4.If error persists, Replace the driver PCA.
5. Replace the main drive assembly.
Dec 06, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Epson ink cartridges, always empty?
Epson has gone to great pains to ensure that third-party cartridges dont work. They really did a good job. Sometimes their printers wont even recognize genuine Epson cartridges. I saw a CX8400 with a brand new cartridge claim it was out of cyan ink after printing one 4 x 6 photo. Then it would recognize any cyan cartridge. It had to go back to Epson for replacement. Sign in China com Online Wholesale for AD Signage Product
Apr 22, 2014 | Office Equipment & Supplies
It displays either code 59.51 or10.92.02 not engadged
It's likely either a bad Cyan cartridge or ribbon cable pinched. This is what I found on DepotTechSupport (so the solution isn't mine, just the searching) :-)
59.51, 59.61 ERROR
http://depottechsupport.com/index.php?/Troubleshooter/Step/View/8
59.51 ERROR 59.61 ERROR An error occurred with the cyan printcartridge drive motor during startup or rotation. 1. Check that connectors J5004 on the cyan print-cartridge drive motor and J207 on the driver PCA are seated correctly. 2. Replace the cyan print-cartridge drive motor. 3. Replace the driver PCA
10.92.YY CARTRIDGES NOT ENGAGED
10.92.YY CARTRIDGES NOT ENGAGED The print cartridges are not engaged correctly. YY Description: 00 Black 01 Cyan 02 Magenta 03 Yellow 1. Open and then close the front door. 2. Make sure all the print cartridges are seated correctly. 3. Turn the printer off and then on. 4. Inspect each cartridge lock-lever (on the right side). Open the front door and remove all cartridges and the ETB. Then use the ETB holder on the right side to move the lock-levers up and down. Replace the cartridge lock if it is broken. 5. Inspect the right side cam. This piece controls the movement of the cartridge engagement arm, the cartridge shutters, and the OPC drive. You can inspect this piece without taking off the covers by wiggling the white rod arm on the right side of the ETB. If it moves easily, the part is broken and should be replaced. 6. Inspect the ribbon cables. Folded or damaged ribbon cables can cause a short that generates an error. 7. Inspect the cartridge guide rails to see if any are damaged. 8. Upgrade the DC controller firmware. 9. Clean the contacts on the memorycontroller PCA. 10. Verify that contact is being made with the E-label PCA on the print cartridge. Replace the print cartridge if the Elabel PCA is missing. 11. On the DC controller, make sure that connectors J1022 and J1023 are seated correctly. On the driver PCA, make sure that connectors J201 and J401 are seated correctly. 12. Check the gears on the print-cartridge drive motors. Replace defective motors.
Sep 09, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
HP CLJ5500 does not recognize the cyan cartridge.
Hi, Insert the cartridge or make sure the cartridge is fully seated.Verify that the connectors between the memory tag antenna, memory controller board, and the DC controller are seated properly. importantly check cyan drum rotation sensor is seated properly and clean the sensor will servethe purpose.
Sep 23, 2011 | HP LaserJet 5500dtn Color Printer
Cyan ink discharge at the back of the ink crtrige.
The leak is from the cyan ink cartridge or from the connections in the ink tube system. Replace the ink cartridge first. If that does not fix the problem, replace the ink tube system.
Jan 13, 2010 | HP DesignJet 1050c InkJet Printer
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Why does my IPF700 plotter print cyan lines on the whole print?
Are you using the correct drivers? If the answer is yes you either have a bad (or dirty) printer or, a bad ink cartridge.
Nov 24, 2009 | Canon iPF700 InkJet Printer
Plotter only printing in Cyan
Check your black cartridge. Do the pump the cartridge thing with the plunger on the left of the plotter. Check all the electrical connectors on the cariage and the cartridge - clean with water -or wd40 if you are very careful and check that all the contacts, about 40 of them are clean and undamaged on each cartridge. Replace with known working cartridges. run a color test as specified in the manual -- hp has relased the manual for this printer as they no longer service this unit.
Jun 23, 2008 | HP DesignJet 450c InkJet Printer
Printer won't recognize ink cartridge
I had the same problem with the yellow cartridge.   At first when I resinserted it, it would solve the problem, but today even that didn't work.
I did solve the problem by clearing all print jobs, turning the printer off and then on, and then running a cleaning cycle on the color nozzles.   I don't know why this fixed things, but my yellow was suddenly recognized without any further fiddling.
Sep 07, 2007 | OEM Systems PIXMA iP3300 Photo Printer
183 people viewed this question
Seeker5211
Seeker5211
